Old 02-18-2017, 01:26 PM
pa38112 pa38112 is offline
Default RV6 Bearing Numbers
Does anyone have the Timken bearing and race part numbers for the standard Cleveland main wheels?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 02-18-2017, 03:29 PM
rv7charlie rv7charlie is offline
The numbers for the slightly 'looser tolerance' versions are
08125 bearing
08231 race
You get to decide whether its worth paying roughly 5 times as much for the space grade version (numbers escape me....)
Charlie
Old 02-18-2017, 03:52 PM
Thank you ! - There is nothing to decide. The fit is set by the pre-load not the manufacturing tolerance. The fit is very course considering you have to back off the nut until you align the cotter pin. A tighter tolerance won't do anything but add cost
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 02-18-2017, 04:37 PM
To be clear, this isn't about preload. The 'loose' tolerances is a reference to how tight the machining is on the rollers and raceways. If someone posts the p/n's for the actual spec'd bearings, you can look up both & see the numbers.
Think machined to 4 digits past the decimal instead of 6 digits past the decimal; that sort of thing.
Not implying that the numbers I gave you are trashy bearings; they're not. But the original numbers are tighter tolerance.
Charlie
Old 02-18-2017, 05:18 PM
Larco's Avatar
Larco Larco is offline
I am not at the port but do have the part #s there. If you don't come up with what you need email me and I will get the info to you. If you look at the side of the bearing or the race the # will be stamped there and Napa or other part stores should have the none certified version of them. IIRC the aviation # has an A added on to it? Larry
Larry
Old 02-18-2017, 06:21 PM
Here's a writeup from a vendor hyping the advantages of 'aviation grade' vs 'automotive'.
http://www.mcfarlaneaviation.com/Pro...tNumber=08125&
The vendor's statement is pretty much what I've always heard about the difference (from vendors :-) ).
According to the link above, you add the suffix -20629 to the numbers I gave you to get the 'aviation grade' bearings.
Charlie
