Yes
Terrell,
Yes that was the name of the kit I purchased through Van's.
A few things I learned along the way that may be helpful.
1) Green Locktite worked great if you can get away with that fix.
2) Napa sells an epoxy if you have an outside leak that you need to fill and can see.
3) I purchased a 5" hole saw from Lowe's for about $25.
4) If you want to do it right and leave yourself easy future access purchase sealing nut plates and attach with panel with screws instead of rivets.
Hope that helps and good luck with your screen doors, I am thrilled every day I walk into the hangar and there isn't fuel on the floor:-).
Drippy
