02-12-2017, 04:47 PM
VP100 and the PHAviation relay board
Folks,
I have wired up my infinity sticks and have the VP100 system. I also have the PHAviation relay board.
Just curious....do I even need this relay board if I'm operating the VP100?
Don
02-12-2017, 05:47 PM
Hi Don,
My VP-100 did all of the trim work. Nothing else needed.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
02-12-2017, 05:56 PM
Great...
Thanks Tom,
Your old VP100 is working fine!
Don
02-12-2017, 06:56 PM
Don, just follow the instructions and wire the VP-100 directly to the trim motors!  No relay board needed like Tom said.
Marc
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
02-12-2017, 10:13 PM
Thanks.
I removed the relay board Marc and wired to the VP100 accordingly.
Will the flaps work without the Ray Allen POS-12?
For some reason, the flaps wont work, but everything else is. I tried to go into to flap settings enable it and follow the directions, i have no flaps and it wont let me save any if the settings?
The flap motor works as i tested it today. I have a D180 as well. Cant figure it out.
Don
02-13-2017, 02:02 PM
Were good!
Shout out to Mark Olsen!
Didnt realize i had to make up numbers for the up and down limits to get the flaps working.
Thanks for the help Mark!
Don
02-25-2017, 07:22 AM
Hi Don,
Yes you can use it without a POS-12, but you won't have a flap position reading other than your eyeballs to look at the flaps.
Also, the only thing to limit the flap position at the endpoints is the limit of the flap motor travel, which in the case of the Vans motor is generally OK.
Be sure that you use a momentary up and down flap switch, otherwise the motor will continue to run and you'll get a flap fault.
Marc Ausman
02-25-2017, 09:21 AM
Thanks Mark
Got the flaps working just fine. Just trying to get the POS-12 adjusted properly so that I can mount it.
Onto the aileron trim, which I tied into the D180 as per the instructions on the VP forum...I'll let you know how I make out!
Don
