Old 01-25-2007, 11:24 PM
Captain Sacto Captain Sacto is offline
Default Dimpling near leading edges?
Question for the experts.
I'm just starting to dimple my horiz stab skins (RV-7), and I'm wondering how the experienced among us dimpled the holes closest to the leading edges.
Do you pry the surfaces apart, and use the c-frame? Or, do you get a better result using the pop-rivet or hex-head dimpler?
All suggestions and advice are welcome and appreciated.
With regards - -
Tom in Sacramento
Tom in Sacramento.
RV-7A, Emp Kit finished (only 2 yrs!).
Wing construction officially started.
N7877A Reserved. Planning to call it "The STREAKER"
VAF # 1635
Old 01-25-2007, 11:34 PM
Pirkka Pirkka is offline
You'll get statisfied results with pop-rivet dimpler. And if you would just follow instructions, you would be already left that stage of the building behing a long time ago...
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 01-25-2007, 11:49 PM
G-force's Avatar
G-force G-force is offline
Pop rivet dimpler, worked great for me.
Mike Sumner
Castaic, Ca
Old 01-26-2007, 08:16 PM
osxuser's Avatar
osxuser osxuser is offline
I used the c-frame. But for the Elevators you'll have to use the pop...
RV4 wing in Jig @ KPOC
RV7 emp built
