Old 02-10-2017, 02:37 PM
simatos simatos is offline
Default main wheel caliper bracket question
Having some confusion regarding axle flange U-403 and caliper bracket placements. Looking at the axle with threaded end closest to me, you
install the U-403 axle flange. Question is: does the caliper bracket mount to the outside (wingtip side) of the flange OR on the inboard side (fueselage side)
of the flange. I am using the C2 drawing not clear to me.
Thanks Gary
Old 02-10-2017, 05:27 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Hope this helps
I get brake caliper grease at Advance Auto and apply it to the back of the plate where it contacts the puck and on the pegs that go through the plate. It is sticky and it lubricates those parts well. (This does not come in contact with the aircraft specific brake fluid). Those mounting bolts will loosen over time and will have to be tightened down, you'll know when your wheel pants start to wiggle as you are taking them off.
Here is some info to keep in mind also. When you remove your brake pucks in the future to clean them be sure to put them back in correctly, o-ring side first. They can be put in the other way, but after the first few time that you use them, the o-ring will come out to far and you will lose all your brake fluid and you will have no brakes.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 02-10-2017, 05:59 PM
RV7ator RV7ator is offline
Take a look at the last several posts on this thread:
http://www.vansairforce.com/communit...ighlight=brake
The discussion revolves around insufficient clearance between the brake disc and wheel fairing attach plate. Van's specifies 1/16", which IMHO is way too small, especially since you'll be instructed to beef up the drilled holes in the fairings with layups on the inside, which tends to diminish your established clearance. Put the layups on the outside and fair them in.
Also, I would be wary of using a lubricant from an auto application. The materials in aircraft systems are specific for aircraft brake fluids.
John Siebold
Old 02-10-2017, 08:07 PM
Talking
Gentlemen, again you have pulled my butt outta the fire, exactly what i was looking for
Cheers
Gary
