Old 04-28-2017, 09:38 AM
flybill7 flybill7 is offline
Default Priming
On my slow-build RV-7 project, finished in 2009, I used self-etching rattle can primer on the non-alcad parts. I scuffed up the parts with scotch-brite, then cleaned them well before spraying. It's hard to believe, but I've been happily flying my 7 for eight years now, and have over 1,000 hours on it. It's always been hangared; the airport is just off the Chesapeake Bay. I have yet to see evidence of any corrosion on the airplane. I can tell you the airplane is going to last a lot longer than I am!
Bill Cloughley
Severna Park, Maryland
RV-7 Flying (1,400 hours)
http://www.pilotbill.com
Old 04-28-2017, 10:38 AM
rv7charlie rv7charlie is offline
I own a -4 that was built in '91. Spent its 1st 20 years in Arizona; rest of the time in Mississippi. Only light discoloration on the inside of the wing bottom skins. (And some light corrosion around chipped paint on the outside...)
This thread is the 1st time I've heard of alclad being called a 'conversion coating'. Supporting docs? I've always been told that it's just a super thin layer of pure aluminum applied to the 2024 alloy.
Charlie
Old 04-28-2017, 10:50 AM
majuro15's Avatar
majuro15 majuro15 is offline
I had my tail cone in a basement for just under a year. Despite having dehumidifiers down there, moisture found a way around the bottom skin and battery mount ribs and cause a lot of corrosion. I had hastily sprayed the Duplicolor self etching primer (not applied well, my fault) and it corroded underneath the primer.
I regret not priming!!
I started using SEM out of a spray can for ease of use on the wings and fuselage. Great product, tough as nails, easily applied.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
Old 04-28-2017, 12:39 PM
TFeeney TFeeney is offline
Tim - I've seen your blog pictures and it was heart wrenching to me.
Can you elaborate on what you think went wrong? Why that one area?
RV10
QB Wings done
Fuselage done
Systems and electrical...
Old 04-28-2017, 03:51 PM
majuro15's Avatar
First it was storing it in the basement. However, I will say that the basement was still a much more controlled envrionment than what an airplane will see in it's normal life (outside, rain, hot humid hangar, etc). I had it sitting on the ground with just a scrap of carpet underneath. I believe the metal acted as an attractive surface for moisture to collect and that happened to be the lowest spot.
Second, it was the condition of that piece. The tail kit is old (originally purchased in 2004) and there were more than a few scuffs and scrapes to that area. Any damage to the pristine surface of the Al from Van's can invite corrosion if not properly treated.
Third, was the crappy application of primer. The original builder did not prime for several reasons of his choosing. I went back and forth and decided against it initially. However, after seeing more and more light filiform on pieces, I changed my mind and primed. Initially I used the Duplicolor self etching primer and it's not a quality product in my opinion. I also did NO prepping to the tail cone before I shot it. It was a last minute decision before storing it at the time that "hey, some primer is better than nothing at all" thought. I simply spray painted over a completed assembly, so no real protection from it.
My advice is find a method and product that works for you and do it. It can be done simply, quickly, easily, and cheaply. No point in worrying any more than you need to about the condition of areas invisible once it's built.
Primer isn't a guarantee of no corrosion, it's just a form of insurance that I will not build without!
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
Old 04-28-2017, 05:36 PM
JonJay's Avatar
JonJay JonJay is offline
My guess is the carpet did you in, wicking up the moisture in vapor from the concrete.
It is just a guess and not meaning to hinder your other points.
Do not store parts in contact with anything that can absorb or retain moisture.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 04-28-2017, 06:06 PM
Plummit's Avatar
Plummit Plummit is offline
To add to that, Concrete has lime in it. It's very possible that the situation was compounded by the carpet and concrete.
~Marc
RV-10
N814RV
2020 Donation Made
Old 05-17-2017, 02:13 AM
RV7ForMe RV7ForMe is offline
I use 2k chromate epoxy primer that airbus uses on the whole inside.
I have been working on the empenage for a few months. I already have filiform corrosion around rivets on my finished parts on the outside! So I regret not priming the outside as well. I have no way of telling if corrosion is right under the rivets and doing its thing there.
VAF dues paid for 2020
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 06-21-2017, 12:04 AM
Polar Polar is offline
I've also been actively searching for someone who really wishes they had taken the time to prime the inside surfaces. Haven't found a single such story though.
I'm in the 'priming everything, but not sure why' group. It sure adds a pile of work, so far that's all I can see. Hopefully one day I'll find myself incredibly glad I did, although that might be as unlikely as finding someone that is terribly regretful for not priming!
