Old 02-05-2017, 10:20 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default EGT Probe gasket or washer needed?
Hi,
My EGT probes look like this - very sorry for the huge image - I hope it scales properly. If not, you can click on it and it will go to my blog with a normal sized image.
Should there not be some kind of washer or gasket there where the probe is welded to the hose clamp?
Thanks!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 02-05-2017, 12:38 PM
RV6_flyer's Avatar
No gasket or seal. In a short while they are sealed with the tan exhaust coating that forms inside your tail pipe if the engine is running properly. After a long time, they are sealed so well that they will be next to impossible to remove without breaking.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-05-2017, 01:37 PM
rv8ch's Avatar
Default sealing
ok, thanks a lot for the info!
Mickey Coggins
http://rv8.ch
"Hello, world!"
