Old 02-04-2017, 03:54 PM
pastranafan5 pastranafan5 is offline
Default 2 batteries
Is anybody here running 2 batteries? If so, do you have a picture of your setup?
Old 02-04-2017, 06:03 PM
rv7charlie rv7charlie is offline
Do you have a copy of the Aeroelectric Connection book? There are several Z-figures that detail dual battery setups.
Charlie
Old 02-04-2017, 08:03 PM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Default Two Batteries
I have an electrical system with two batteries. I fly my RV-7A in hard IFR conditions and wanted a very robust/redundant electrical system.
Under normal conditions, the batteries are in parallel, thus charged normally. If there is a main buss under voltage they are automatically separated , but through diode coupling both batteries are still available to power the essential avionics.
The batteries are also separated during engine startup, allowing ALL the avionics to be powered up during engine start.
This system is different than those depicted on the aeroelectric site. IF you would like a copy of this setup email me at wstucklen1 at cox dot net.
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
