Old 01-24-2007, 08:29 PM
Rex
Posts: n/a
Question 1990 O-320
I've got a 0 time Lycoming O-320 bought in 1990 as part of an RV4 kit, and need to know if there are any service bulletins for it.
I'd also like some advice on anything I should do to prepare it for use.
Inquiries to the Lycoming distributor yielded no results.
Old 01-24-2007, 08:51 PM
Mel's Avatar
Mel Mel is offline
First are you sure it is a "O" time engine or is it "O" time since overhaul. Only the manufacturer can "O" time an engine. You'll need the dash number (suffix) if it has one. If the engine was re manufactured in 1990, there's a good chance that the oil pump may need looking into. I believe it is AD 96-09-10. Issued in 1996. Go to the FAA website and search for ADs on your particular engine.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-25-2007, 08:34 PM
Rex
Posts: n/a
Mel-
This engine was bought new with the kit through Van's. I probably should have said "new" rather than 0 time.
I'll go to the FAA site to see what I can find.
Old 01-26-2007, 06:41 PM
Rex
Posts: n/a
Mel-
What I found at the FAA Website was 2090 references to a search for O-320!
Old 01-26-2007, 06:49 PM
Mel's Avatar
Mel Mel is offline
Rex,
I don't know. I went to the FAA AD page, typed in search for O-320 and came up with 38 results.
If you add your suffix, (I suspect your engine is a -D1A if purchased through Van's) the search narrows to 12 items.
Old 01-26-2007, 09:38 PM
osxuser's Avatar
osxuser osxuser is offline
Probably the easiest way to go about this one is to just go to your local shop and ask them to do a ad/sb search for you. Might cost a few $$ but it'll probably save you some aggravation.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 01-26-2007, 10:29 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Use the FAA site...
Why bother... the FAA web site is free, and is the "master copy"
If it is a O-320-D1A, then only four ADs are dated after 1990...
2006-12-07 07/11/2006 ECi cylinder assemblies
2004-10-14 06/25/2004 Crankshaft gear
98-02-08 03/30/1998 Crankshaft
96-09-10 07/15/1996 Oil pump
I even turned them into hotlinks with Doug's nice posting scripts...
If you are clever enough to navigate around this site, then the FAA site should be no problem....
AD main site here...
http://www.airweb.faa.gov/Regulatory...TOKEN=32851978
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-27-2007, 06:54 AM
mahlon_r mahlon_r is offline
Gill,
I think there are more AD's then that! Try searching for O-320 or 320 instead of O-320-D2A only. It will return any ad's with 320 in it.They may not specifically apply, but there are several AD's that aren't on your list.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 01-27-2007, 08:34 PM
Rex
Posts: n/a
Maybe I'm using the wrong search location.
From FAA's home page, I selected "Mechanics" at the top right.
At the Mechanics page I typed O-320 in the search window and got 2090 results.
If I select the ADs option in the Mechanics window, then search O-320, I get the 38 results Mel pointed out.
osxuser-
I emailed the closest Lycoming distributor (1 hr. away) requesting this info and received no response.
