Old 02-02-2017, 11:47 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Thumbs down wheel bolts over torqued
Today I was changing a tire for a friend. His RV-8 was built three years ago and sports about 80 hrs.
The builder, my friend -during the building - was helped by the 'expert' in the wheels and brakes during the wheels assembly, not an airplane mechanic
That guy never use the torque wrench, it's for bubba he says.
It was really difficult (I really didn't understand why) removing the three bolts that keep the inner and outer half of the wheel. This is what I found:
- all bolts thread destroied
- two bolts bended
I can't imagine how much power the expert ironman put in.
Build safe, everything has its own reason.
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 02-02-2017, 12:05 PM
Bill Dicus Bill Dicus is offline
Default torque
Wow! You northern Italians are strong... And take good photos of the Dolomites!
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 02-02-2017, 12:34 PM
Bavafa Bavafa is offline
Just curious how over torqueing can cause the bolt to bend. It looks like the two halves have rotated some how or else.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 02-02-2017, 12:50 PM
Rupester Rupester is offline
The torque wrench is our friend.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 02-02-2017, 02:14 PM
snopercod's Avatar
Default bold bending?
I agree with Bavafa: You can't make a bolt bend like that by over-torquing - there has to be some kind of a side load. I'm also suspicious that the damaged threads were caused by over-torquing as well. The really bad threads on that last bolt almost look like someone tried to screw a coarse-thread nut onto an AN bolt.
(2020 dues paid)
Old 02-02-2017, 05:50 PM
Steve Melton's Avatar
weird. it took a significant load to bend that bolt.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 02-03-2017, 07:36 PM
Hawg Driver's Avatar
Hawg Driver Hawg Driver is offline
Default Air Pressure
If you have a compete brain failure and remove one bolt before removing the air pressure from the tube, it will bend the two remaining bolts.
Don't bother asking me how I know...
Patric "Balls" Coggin
RV-4: Purchased Flying
2019 Dues Paid Up
Old 02-03-2017, 07:57 PM
xblueh2o xblueh2o is offline
That was kind of my first thought when I saw the pictures.
Because I have never done that before, and I will never do it again.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 02-03-2017, 09:22 PM
RV7A Flyer's Avatar
That sounds like a potentially lethal accident waiting to happen
Old 02-04-2017, 12:51 AM
Good to know but this wasn't our case. The core valve had been already removed and the tire separated from the halves.
BUT with further investigation, despite the destroyed bolts thread comes probably by on over torqued, the recent story of a ground loop of the airplane open my eyes.
I didn't notice twisting in the halves but IMHO the case is closed.
The winner are "Bavafa" and "Snopercod".
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2020
