Old 02-02-2017, 08:13 AM
Byron7 Byron7 is offline
Default Control Cable boots/seals
Looking to find the rubber boots on the end of the mixture/throttle cables. Tried the ACS company that makes the cables,but don't seemed to be interested.
Old 02-02-2017, 08:18 AM
krw5927 krw5927 is offline
Small:
http://www.aircraftspruce.com/catalo...lickkey=732385
Large:
Someone said the ones they send now are the more robust blue ones, which is a good thing. You might call and check.
Kurt W.
RV9A
FLYING!!!
Old 02-02-2017, 08:26 AM
Default Seal/boots
Thanks, will check them out.. Mike
Old 02-02-2017, 08:50 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
They should be the blue ones, even though last year when I purchased mine, the pic showed black ones. I had mine all swapped out at annual, as the black ones all cracked and split. If only grommets came in this mystery blue formula!!
