Old 02-01-2017, 09:55 AM
Charles in SC Charles in SC is offline
Default Posting photos
What is the easyist photo host to use? I am not a computer guy at all. I tried Photo bucket but could not figure out how to do it. I spent way to much time trying to close ads that kept popping up. I decided it was more trouble than it was worth.
Thanks in advance!
RV 7
Old 02-01-2017, 10:11 AM
wirejock's Avatar
wirejock wirejock is offline
I prefer Tinypic.com.
Works best when the photo is horizontal.
Select 640 x 480 for message board.
Upload
Copy the I'M boards link
Click on the VAF photo link button
Paste but make sure there is only one set of "[img]" brackets on each end of the link.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-01-2017, 11:04 AM
johnbright's Avatar
johnbright johnbright is offline
Default Google Photos
I use google photos but you have to set the sharing correctly... there is a learning curve. One gotcha is if the sharing is not correct and you are logged in to Google you will see your photo in your posting but the rest of the world will not.
On the plus side, it's where I keep all my photos and I don't plan to ever move them so the links will never break.
Old 02-01-2017, 02:13 PM
RV6_flyer's Avatar
Default Photobucket
I have been using Photobucket for years. It even generates the CODE needed to post from an iPad.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-01-2017, 02:18 PM
AviatorJ AviatorJ is offline
I used postimage.org, probably the same as photobucket... you upload an image or set of images and it gives you the cut and past to post to a forum.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
