Old 01-31-2017, 06:09 PM
Default Dynon ADAHRS in RV-3 or -4
What location have you found that you've flown and that works?
I'm building a -3B and the tailcone's a bit on the small side. I'm dithering between the stabilizer shelf in the back and the bulkhead (F-308) aft of the baggage compartment. My plane will have a pitch servo at the bellcrank behind the baggage compartment.
Dave
Old 01-31-2017, 08:33 PM
rvator51's Avatar
rvator51 rvator51 is offline
I put mine on the bulkhead art of the baggage compartment and seems to be fine there.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 02-01-2017, 03:14 PM
Raymo's Avatar
Raymo Raymo is offline
Not sure how similar the F-1 Rocket is but we just installed one on the bottom side of the aft baggage compartment floor using some standoffs to keep the top side on top.
It could be on the top side of the floor as well but wasn't as clean an installation.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-02-2017, 11:59 AM
n82rb's Avatar
n82rb n82rb is offline
on my 4 i mounted it with two square aluminum tubes across the fuse mounted to the two .063 angles on the sides.
bob burns
rv-4 n82RB
Old 02-02-2017, 01:41 PM
Bob, fore and aft, where?
Thanks for this and to the others as well.
Dave
RV-3B building the fuselage
Old 02-02-2017, 05:47 PM
n82rb's Avatar
i would need to look at the plans to get the former numbers but its between the former that forms the rear of the baggage compartment and the next one back. i use two 1/2 x1/2 inch square tubes. i used #8 nylon screw to mount them to the angles and to mount the adhrs to the tubes.
bob burns
RV-4 N82RB
Old 02-02-2017, 07:02 PM
Okay, I know where that is, thanks.
Dave
