GalinHdz
I have a nice video camera which has an external audio input jack that I want to connect to the rear seat intercom jacks and record in flight conversation. But the camera audio system is 8ohms while the airplane audio panel is 600ohms. If you connect them together without some kind of impedance matching, recorded audio gets very distorted and might even damage the airplane audio panel. Being the cheapskate that I am I decided to put what little EE knowledge I still have to good use so I designed and built an inexpensive 8ohm to 600ohm audio adapter. My audio panel is mono while my camera is stereo so I went with a 1/4" mono plug and a 1/8" stereo plug. It is just a simple resistor voltage divider and I got all the parts at my local Radio Shack. If your audio panel is stereo, use a 1/4" stereo plug instead of a mono plug and use two resistor voltage dividers each one connected to each one of the stereo (L / R) channels.
The resistors are 1/4w (1M Ohm / 100K Ohm) and are so small they fit inside the 1/4" male mono plug.
This is how it is all wired up:
I have used it several times and the recorded audio quality is excellent. It took about 1hr to build and I spent less than $15 for all the parts.
