O-320 cylinder spacing
Does anyone have a dimensioned drawing that shows the distance between the centers of the cylinders on an O-320? I am making a split plenum and that dimension would make it easier to fabri-cobble the inner baffle wall which will go against the lower cylinder barrel fins. I could just rough measure it, but knowing the real value will make it easier.
Scott Black
VAF dues 2020
Instagram @sblack2154
