Old 01-30-2017, 08:59 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Beringer brakes.... Dot 4 or MIL fluid?
Ok guys, I'm about to order the Beringer brakes. You can choose which fluid you will be using. The lady I spoke to at Beringer said most people from the US choose the MIL-PRF-87257 fluid and most in Europe use the DOT-4. Sounds like there are pros and cons to each. Which did you choose and why?
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 01-30-2017, 09:13 AM
Order the cylinders with the Nitril seals for 87257 fluid. The EPDM seals are for DOT4, automotive brake fluid.
Tom
Ridgeland, SC
Old 01-30-2017, 09:16 AM
RV6_flyer's Avatar
Default MIL-PRF-87257
MIL-PRF-87257 is synthetic MIL-5606 that does not burn (catch fire) as easy. It will still burn but reduces the risk of a brake fire over 5606. MIL-PRF-87257 can also be mixed with 5606. IF you are on a trip and land at an airport, there is a good chance you will be able to find seals and brake fluid at the airport that will work without having to make a trip to an auto parts store.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-30-2017, 10:19 AM
bret's Avatar
bret bret is offline
I'm Experimenting with my Experimental, DEX 6 ATF, flash 428 F. compared to the aviation stuff 458 F. so far so good.
Old 01-30-2017, 12:00 PM
For nitrile seals, NOT for EDPM seals.
Tom
Ridgeland, SC
Old 01-30-2017, 02:54 PM
Av8rRob's Avatar
So, the opinion is the mil is better than dot-4 fluid?
Rob Lasater
Paid Dec 2019
Old 01-30-2017, 03:02 PM
YellowJacket RV9 YellowJacket RV9 is offline
I have recently done the same research and decided on the Royco 782, aka MIL-PRF-83282, http://www.aircraftspruce.com/catalo...?clickkey=4008
Higher flashpoint than the 5606, no seal or compatibility issues, so I don't have to worry about completely flushing my system, or topping off with 5606 somewhere if that's all I can find. I am also going ahead and replacing my brake lines with stainless flex hose down the gear leg to make future service easier.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 02-01-2017, 07:14 PM
Av8rRob's Avatar
Ok, so I ordered the mineral oil kit today. FYI, they are offering 30% off their kits now if you're on the fence.
Rob Lasater
Paid Dec 2019
Old 02-01-2017, 07:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Brake fluid
Mineral oil kit?
I thought you were going with Barringer recommendation MIL-PRF-87257?.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-01-2017, 07:35 PM
Av8rRob's Avatar
Yes, I'm getting the set with the nitrile seals for that type of fluid.
Rob Lasater
Paid Dec 2019
