Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 01-28-2017, 12:40 PM
Turbo69bird Turbo69bird is offline
Default Sky vision extreme salus portable
Anyone using the sky vision extreme salus portable ADSB in and out unit?
http://www.skyvisionadsb.com/?page_id=2
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
Old 01-28-2017, 01:43 PM
DennisRhodes DennisRhodes is offline
No, but all the parts and documentation look familiar.
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 01-28-2017, 06:07 PM
The built in version sure does, but the portable glare shield mount similar to a stratus, gel, or other type isn't as familiar.
Looks like it doesn't work for the mandate for 2020 because of portability but not 100 % sure. Looks like good bang for the buck compared to other portables since it does both but being so close to the 2020 mandate might not make sense,
Old 01-28-2017, 08:50 PM
There's a number of products out now that advertise ADSB In and Out that are not TSOd and their ad usually states "suitable for Experimental service" such as the SkyGuard xx. Some do "look" like portable units and may work for Wx ,Traffic but I bet the FAA won't allow any inside the mandated airspace come 2020. I'm guessing this is what the programming bit is with Navworx. Seems like the FAA is not going to recognize anything as legit unless it transmits an SIL of 3 and an SDA of 2. And with that They know it is TSOd. So much for the "meeting performance" standard.
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 01-30-2017, 10:00 AM
So I've read the sil 0 sil 3 thread about the navworks 600b but that sounded like it was going to be only the early models. Is it an issue with all navworks boxes? Or is it the portability issues they don't like?
Old 03-17-2017, 11:55 AM
A little added reading on the subject. To bad this is a nice solution at a nice price I'd be happy to bolt it in and hook up to an external antennae for the cost savings and the quick route to compliance.
http://www.aviationconsumer.com/issu...15_6770-1.html
