Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 01-25-2017, 02:56 PM
tgmillso tgmillso is offline
Default Electronic ignition, engine and propeller compatability
Hi All,
I recently ordered a set of E-Mag Series 114 P-Mags for my IO-360M1B and Hartzel 72" blended airfoil propeller (C2YR-1BFP/F74972) combination (one of the standard orders available from Van's for the RV-7). Before I got around to installing the P-mags I realized that I hadn't considered the torsional vibration/blade vibration impacts of running electronic ignition on this combination of engine and propeller. I have contacted E-Mag and they have no specific instances of this combination and are not really aware as to how one would test the setup to ensure it is an acceptable combination. I did a bit of digging on the internet and found an list of approved aircraft types for the Electroair EIS-41000 ignition, which included a huge array of aircraft that have aluminium propellers (which gave me a little more confidence that my combination will work).
http://www.aircraftspruce.com/catalo...l-08-05953.pdf
Brad from E-Mag also forwarded some documents released by Hartzell/Vans that gives a restricted operating range for engines equipped with Lightspeed ignition:
https://www.vansaircraft.com/pdf/Hartzell_c2yk.pdf
And more specifically for the "Blended Airfoil" propeller:
https://www.vansaircraft.com/pdf/Hartzell_c2yr.pdf
Thus, the questions I have are as follows:
1. Does anyone have operational experience running the P-mags (or any other electronic ignition) with this IO-360M1B and Hartzel 72" BA propeller combination (or 74" for that matter)?
2. Is anyone aware and prepared to share the methodology that one must follow to perform a vibration analysis for ensuring acceptable compatibility of this hardware combination?
Regards,
Tom.
Old 01-25-2017, 04:05 PM
Bevan Bevan is offline
See this thread for a recent similar discussion which includes contact info for Les at Hartzell who is very responsive via email for these types of questions.
http://www.vansairforce.com/communit...light=hartzell
I'm running a similar (not exact) combination.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 01-25-2017, 06:45 PM
rzbill's Avatar
rzbill rzbill is offline
Follow the link from Bevan and find prop limits 2 in my post and look for the post from Les Doud . The M1B is approved with your prop and a lightspeed so it is up to you to decide whether the lightspeed and your EI are similar.
Bill Pendergrass
ME/AE '82
Old 01-26-2017, 03:59 AM
Excellent. Thanks guys for the pointers. This is good to know.
Sounds like we are in the clear.
For others reading this post, here's the link to the Hartzell application document. This particular combination may be found on page 1402.
http://hartzellprop.com/wp-content/u...000-R56-WA.pdf
Tom.
Old 01-26-2017, 08:00 AM
DanH's Avatar
DanH DanH is offline
Which should be a question of timing, not necessarily the fact that it's electronic.
Another good reason to make ignition maps public, BTW.
Dan Horton
RV-8 SS
Barrett IO-390
