Old 01-25-2017, 10:52 AM
Katie, thanks for posting all this. It's very helpful and timely since I'm sorting through the "where should this go" issues with my RV-3B. Sure is a small airplane, isn't it?
The discussion of the magnetometer is especially helpful. Much appreciated....
Thanks again,
Dave
Old 01-25-2017, 11:06 AM
Hey Katie---outstanding job of creating this package. I think you'll love it!
Tom
Ridgeland, SC
Old 01-25-2017, 11:12 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Great write-up Katie!
The only thing you might or might not want to know after all that great work on the magnetometer mount is that Tsam's is on the aft deck, and has worked flawlessly for almost 600 hours of flying. Of course, we didn't go and magnetize any of the hardware back there....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-25-2017, 02:06 PM
koupster's Avatar
koupster koupster is offline
Default Fuse Block
Katie,
Rather than hinge that fuse block, you could configure it so it could slide out from under the panel. no messing with safety wire, and the fuse blades would stay pointed at the belly of the RV-3.
Nice work.
Cheers, David
RV-6A A&P
Old 01-25-2017, 04:53 PM
If you look at many modern automobiles you will likely see their fuse blocks are oriented so there is at least some "upside down" vector on the fuses. I've never, ever had a fuse shake loose. I have, however, cussed fuses many times because they were so stubbornly stuck in their holders and some wingnut had made off with the factory-supplied fuse pulling tool.
As for your comments about GRT, I have their stuff in our current project airplane and believe it's good engineering hampered by absolutely the worst installation and operation documentation. GRT needs to pull up their socks if they want to stay in this game. That having been said, Garmin's business practices have long ago made me wary of buying any of their products. I hope your equipment choice proves, over the long term, to be a very wise and enjoyable decision.
Old 01-26-2017, 07:14 AM
jthocker's Avatar
jthocker jthocker is offline
Default Garmin Rocks!
Hey Katie, glad you finally came in from the cold!!!!!😜😜😜😜
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 01-26-2017, 08:13 AM
Scott Hersha Scott Hersha is offline
I have a similar setup in my RV4 with the tray-mounted avionics and I have a total of 4 fuse blocks. One of them is mounted upside down and nothing has come loose yet (6 months). BUT - I also have one mounted vertically on a small panel mounted to the avionics tray, pointing straight down. It's between my legs/feet and so short that you can't see it without bending to look under the panel. There is no interference, and it's easily accessible without removing anything.
Just another idea to consider....
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 01-26-2017, 09:51 AM
kentlik's Avatar
kentlik kentlik is offline
That is great Katie! You certainly have a great setup there. Looking forward to more updates
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 01-26-2017, 02:41 PM
RBD's Avatar
RBD RBD is offline
Originally Posted by KatieB View Post
Here's an older version of the panel layout. I'll try and put a new one up tomorrow sometime.
Great write-up and an even better panel. The only question that remains: is that short N-number the most expensive part of the panel?
Ryan
Tampa, FL
RV-4 (sold)
RV-8 (sold)
Xtreme Decathlon (borrowing)
Old 01-26-2017, 02:50 PM
sblack sblack is offline
I'm building a 4 with blade fuses and I have been mulling over the fuse block question as well. While the forward fuse top is removable, I don't want to have to do that to trouble shoot a fuse. I haven't been able to imagine a fold down fuse block tray that is simple enough for my liking. So I think I will be going with mounting the block on the fuselage sidewall ahead and below the instrument panel basically where the cowl cheek fairings go. So I will be able to bend down and see the fuse block, but it won't be in my direct field of view. It will add a bit of wire, but I learned on my last airplane to make everything as serviceable as possible.
For your panel design be sure to consider that the canopy frame will obscure the top 3/4" or so of the panel. I'm sure you have, but it never hurts to mention it. I am getting near the end of my FWF so this part of the project is coming up next. I am looking forward to that.
Scott Black
VAF dues 2020
Instagram @sblack2154
