2 comments.
First, do research on trickle charging. Odyssey and similar sealed lead acid/AGM batteries have a very low self-discharge rate (i.e. you shouldn't need to trickle charge within a 6 month window) and those that trickle charge seem to have more longevity issues than those who don't.
I think you'll struggle to find any sophisticated charging circuits on Solar setups and you may struggle to get the exact float voltage you want with moderately priced setups. Also you don't get a lot of amp hours from a fairly large panel at the moderate price points. I looked into these for my sailboat and I needed a 2' X 4' panel to give me anything over the self-discharge rate on two large batteries.
Flooded batteries are more tolerant of trickle charging methods and solar works well for these. Not so sure about sealed lead acid though.
Larry
