Are you the builder? If so did you remove the jumper on the starter solenoid?
I will look up the RVAator article on this and amend this post. The essence is that the jumper should be removed and allow the starter contractor to energize both the power lead and the starter solenoid. The reason is that the starter was found to remain energized after the starter contractor was shut off.
It is a bit of controversy around this, but based in fact from Vans (as a problem resolution) and they have stuck with the wiring recommendation for many years once they isolated the cause.
Edit - Scott beat me to it.
Bill
RV-7
Lord Kelvin:
