Old 01-22-2007, 12:13 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Question Delrin Block Source
Anyone know where I can inexpensively get a delrin block for making a spacer. 7"x7"x1". I can't seem to easily locate one over the web.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 01-22-2007, 12:29 PM
jmbaute jmbaute is offline
McMaster-Carr
mcmaster.com
John B
Mooney M20C (KPSK)
RV7 Wings
www.pdfplates.com
Old 01-22-2007, 12:49 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Chopping blocks
Depending on what you are planning to use the spacer for, I've found many plastic kitchen cutting boards seem to be very similar material. Very cheap at your local Ikea.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-22-2007, 12:55 PM
RV_7A RV_7A is offline
Heres one source...
Delrin Source
and another...
More Delrin
and a good deal on Flea Bay...
Delrin auction...
www.JeffsRV-7A.com
N808TX
Old 01-22-2007, 02:07 PM
Mel's Avatar
Mel Mel is offline
Aircraft Spruce carries nylon which will work as well. (maybe better.) I used nylon for all the bearing blocks in my bi-plane.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-22-2007, 03:46 PM
RVRC's Avatar
RVRC RVRC is offline
Delrin, UHMW and Nylon are similar, but different. Check in your local phone book for a Rubber and Gasket store. I worked with a r&g company for years and we sold it.
RVRC
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
Old 01-22-2007, 05:13 PM
Capflyer's Avatar
Duhh on me. I sell these things for commercial use. Found a cheap 1/2" bar cutting board for $2.80 in my cataloge, liquor not included. It's heat and chemical resistant, neither of which I need for the place it's going. Putting two together for the 1" thickness will work fine.
Thanks to everyone for your suggestions.
Mike
JAMES AIRCRAFT.com
