Old 01-09-2017, 11:04 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Default G3X Touch v5.1 update
Looks like Garmin just released v5.1 for the G3X Touch.
Changes made from version 5.00 to 5.10:
Add ability to configure GEA 24 general-purpose (GP) inputs as additional discrete inputs
Add discrete input configuration to swap frequencies on selected COM radio (requires GMA 245/245R)
Add option to configure distance to destination (DISTD) field in data bar
Change flight director TO mode to always disengage autopilot when activated
Change flight director GA mode to disengage autopilot if minimum airspeed is not configured
Change weight & balance configuration to allow weights up to 99999 units
Improve fuel calculator +/- buttons to more easily enter quantity of fuel added or subtracted
Improve GDU 46x MFD page navigation display when split screen is on right side
Improve engine page display
Improve map airspace labels
Improve transponder status display
Improve Bluetooth & Connext interface
General improvements to system operation
I'm very happy to hear they made the GEA24 GP pins usable as discrete inputs! Especially since I was flying before the GAD27 was made available... I'm going to have to revisit my wiring diagram to see if it's worth a little rewire to take advantage of this!
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 01-09-2017, 11:54 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Hello Ed,
Since you have a GMA 245 and two COM radios that can both be controlled through your GDU 46x displays, you might also be interested in this change:
If you assign this function to one of the discrete inputs on your GEA 24, you will be able to swap the active and standby frequencies on whichever radio currently has the active mic selection on your audio panel. If I remember correctly how your airplane is currently set up, this might be of use to you.
- Matt
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 01-09-2017, 01:06 PM
gfb gfb is offline
Thank you! I asked for this a while back and hoped it would happen. I even saved a button on my stick in case it became reality
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 01-09-2017, 01:19 PM
dweyant dweyant is offline
Love the frequent updates and new features.
However, could we please get an oil use counter? Just a configurable engine hour counter to keep track of the time until oil change would be great!
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 01-09-2017, 02:46 PM
sparkcrafter sparkcrafter is offline
Smile
Very glad to see the change that allows the GEA 24 GP inputs to be used as discrete inputs! Once again I'm impressed with Garmin's responsiveness to customer requests.
Jerald
Old 01-09-2017, 03:46 PM
NovaBandit's Avatar
Originally Posted by g3xpert View Post
Hello Ed,
- Matt
I already have an [on]-off-[on] momentary switch on my stick. Pushing down is wired up to the GMA24 for changing xmit between COM1 and COM2. Pushing up currently activates swapping active and standby on the GTN.
If I understand the new feature correctly, I should be able to rewire the "up" function of the switch to a discrete and swap active and standby of whichever radio is on active xmit (and not just have it always swap on the GTN)?
(the current setup is explained better in my panel tour video at this time mark: https://www.youtube.com/watch?v=lLMh...tu.be&t=31m11s )
Ed Kranz
Old 01-09-2017, 03:52 PM
g3xpert's Avatar
Yes, that's correct - with the latter configuration, activating the discrete input would cause your G3X system to command the radio with the active microphone selection to swap its active and standby frequencies.
- Matt
Garmin G3X Support
g3xpert@garmin.com
Old 01-09-2017, 04:03 PM
NovaBandit's Avatar
I guess I know what I'm doing this weekend!
BTW, you guys rock! Next you need to do something cool with that wifi radio hiding the the GDU460/465!
Ed Kranz
