Old 01-10-2017, 07:19 AM
Robert Anglin Robert Anglin is offline
Default Metric
Originally Posted by RV7A Flyer View Post
I hope they're faster than that
Quickie on-line conversion tool says 170 kts = 525859 furlongs/fortnight! Impress your friends: "This plane goes over half a million furlongs per fortnight! And it only weighs about 35 slugs!"
You know we are supposed to use metric if we can according to Jimmy Carter.
mm. per second would be about as good as you could want to state.
Old 01-10-2017, 09:52 AM
rzbill's Avatar
rzbill rzbill is offline
884,800,000,000,000,000,000 Angstroms per Aeon????
Bill Pendergrass
ME/AE '82
Old 01-10-2017, 10:07 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default MPH or Knots
Here in Canada where I trained in 1981 it was done in MPH for me and I have always had an ASI that indicated MPH and knots were in small letters.
I have noticed the switch in the newer model planes I rent especially the ASI and struggle sometime with the :"conversion". Similar to our late PM sending us into "metric" chaos this does make for some trouble sometimes in the pattern; "have i trimmed for 70 MPH or have i trimmed for 70 knots?"
That is where the fun of this issue ENDS! I hate that momentary confusion on final and twinge of non confidence. So I fly er by the feel and use the ASI as a guide the way we were meant to.
I always just add 10 to the new plane ASI(knots) and hope it is "close enough".
Great thread here! Us old guys always need training eh?
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 01-10-2017, 11:10 AM
sblack sblack is offline
At my Engineering school the problems on assignments and exams mixed up the units. The questions defined the desired units for the answer and you had to convert. Distance could be feet, meters, inches etc. Temps could be C or F, speeds in mph, kph or knots, and the worst, mass, could be kg or slugs. Slugs were my arch nemesis. Try to explain to a layperson why you buy hamburger at the grocery store in units of force (lbs) in America and units of mass (kg) in Canada. Try to explain that a model airplane servo torque rating in g/cm (not even g-cm) is wrong.
Interestingly, after that space probe slammed into Mars a bunch of years back, NASA has gone all metric to avoid a similar screw up. But at the aircraft company where I work, which is in Canada, which is officially metric, we work in imperial units. We will kick out the afm in metric for European customers if they ask for it.
The problem with establishing standards is that it requires humans to agree on something. Humans don't like agreeing on stuff in my experience and I think this thread illustrates that very well
Now about that primer....
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-10-2017, 11:16 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The colonies may have trouble, but I'm always amused at the UK's conversions.
All there are now used (EU based) to buying stuff in kilos and feeling C temperatures, but they still drive in miles and mph, buy petrol in litres but still use MPG for fuel economy...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-10-2017, 01:09 PM
RV7A Flyer's Avatar
I think you mean the one that *missed* Mars, Mars Climate Orbiter.
NASA had been specifying SI units for many years prior to that, but the lower-level software was incorrectly coded (did not adhere to interface spec for SI units, and not caught during V&V).
Old 01-10-2017, 03:32 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Which units you used at NASA depended on which program you were working. The ISS actually has used both. Shuttle was built all imperial, but we used a lot of metric once we started working with the Russians. The truth was - we had to be able to work in both, and regularly convert.
When doing maneuvers, I mostly wanted to make sure I wasn't off by a factor of three (meters per second versus feet per second). And we changed from fps on orbit to knots on the way downhill.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-10-2017, 08:13 PM
RV7A Flyer's Avatar
Yeah, Paul, in truth...even though the policy has been metric for a while, a lot of mechanical stuff on our flight vehicles has been and still is imperial. Old habits die hard. But for MCO, the specs on the s/w were clear...SI units. It just was coded wrong and never caught.
Old 01-11-2017, 02:27 AM
dutchroll dutchroll is offline
I think it's more that people don't like change. Especially major change. It's big and scary and too hard. Even if it makes more sense in the longer term.
I like knowing everything is a factor of 10 and that prefixing it with "milli_ centi_ kilo_ etc" all means something consistent. It's consistent with the entire decimal numbering system. Dividing something up into quarters, eighths, sixty-fourths to get smaller but multiplying by 12, then 3, then 1760 to get bigger.......who the heck thought that system up?
But, as I said earlier, ya gotta be at least bilingual to get by these days!
Mike
Down Under
Old 01-11-2017, 09:41 PM
jay bell jay bell is offline
Originally Posted by N941WR View Post
If you have an EFIS, it should be easy to swap between the two with a few button pushes.
I flew off my test hours in MPH because I was comfortable with them after 20 years of renting and owning small Cessnas and Pipers, and because my transition trainer (Old Blue) used MPH. I switched the Dynon to KTS after I started flying around our countries and talking to ATC a lot. It took a few circuits to get used to the "new" approach speed, but I never considered changing back.
When I want to impress my non-pilot Canadian friends, I tell them cruise speed is 280 klicks, with top speed of 340
Jay
RV7-A
C-FXPT
IO-375, Catto, Electroair, Skyview
400 hours
