Go Back   VAF Forums > Model Specific > RV-14
Old 01-07-2017, 04:27 PM
Reflex Reflex is offline
Default Another Hard To Reach Rivet (Rudder)
I must have done something wrong or missed an instruction. Last night I dry fitted (haven't riveted the skins together yet) my rudder skins. I wanted to see how everything fit before I put adhesive on the trailing edge.
What I found was an extremely tight fit between the skins on the last rivet on the bottom edge of the rudder. It's so close that the rivet actually touches the shop head of the rivet from the other skin. In addition, when in its current position, the factory head sits just a bit proud in the dimple.
Thoughts?
Please see below:
Thanks for your input.
Fred
Dues Paid for 2022
RV-14
Emp Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse Complete
Working on Finishing Kit
Working on Avionics
Old 01-07-2017, 05:04 PM
Tom023 Tom023 is offline
I had same issue. Rather than risk fouling it up I took the safe way out and used an Mk-319-BS rivet and moved on. I've seen photos of others who also took this route.
RV14A #140083
Flying! 8/12/19
2020 Donation
Old 01-07-2017, 05:19 PM
rvbuilder2002's Avatar
The latest rev. level of the rudder plans (dated 12/03/15) specify final drilling #33 and installing MK-319BS rivets in the aft most holes.
Available HERE
You don't have to use blind rivets on all the holes specified if you have a way to install solid rivets.
BTW, it looks like you may be over squeezing some of your rivets slightly (they look a little on the thin side)
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 01-07-2017, 05:37 PM
Gentlemen,
Thanks for the input. I'll use the MK-319BS rivets.
Regarding the rivet height, I agree, they look thin. However they fit perfectly in the gauge. I've found that some of the call-outs can be just a tad short (and some a bit long). In this case, 3-3.5's were specified. Going through the skin, R00904B-1, and R-00918 seemed like a bit of a stretch. They looked short so I checked them with calipers....they were of proper length so I used them.
Should I drill out and use 3-4's? Hate to drill out that .016 skin.
Fred
Dues Paid for 2022
RV-14
Fuse Complete
Working on Avionics
Old 01-07-2017, 06:12 PM
cczarnik cczarnik is offline
Minimum driven head thickness .038 per Mil Spec. That's a lot thinner than what you get with the 1.5D rule of thumb for the shop head. For reference that is very thin- less than a #60 drill bit. Source: https://www.vansaircraft.com/public/Specs.htm. So you're probably ok.
For tight rivets look up the indirect back rivet technique video on EAA's website. That might not even work for this spot though- I used pull rivets.
Chuck
7a emp complete, wings underway
VAF Dues paid - 2018
Old 01-07-2017, 08:46 PM
wjb's Avatar
wjb wjb is offline
I hated these guys ... Van's should have offset them so you wouldn't have the space constraint.
I used the EAA indirect back rivet technique. Worked OK in the end, but my sailor gene surfaced in the process (%$#*!)
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2022 donation happily made
Old 01-07-2017, 08:52 PM
Originally Posted by Reflex View Post
Gentlemen,
Fred
As described in Section 5, the rivets called out in the plans will result in shop heads that meet the Mil Spec (posted by cczarnik), but not necessarily meet the rule of thumb which is what the rivet gauges are measuring to.
The reason this is done is because often when a rivet size is selected that will meet the rule of thumb it is actually just a bit on the long side which makes it
much more likely that a novice builder will have a bunch of them clinch over and then they start removing rivets and things go bad quickly.
A good practice with the rivet gauges is is to get it close to meeting the diam. requirement. You are then probably also close to meeting the height requirement. This usually results in meeting both dimensions for the Mil Spec.
Some builders make there own rivet gauges with holes and notches based on the Mil spec values instead of the 1.5/.5 rule of thumb values.
And no, I don't think you need to remove any rivets.... I was just mentioning it as something you might want to keep in mind as you continue.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 01-07-2017, 08:57 PM
Actually, using the .5 rule of thumb for thickness the nominal would be about .047 thick so only about .009 difference. A couple in the photo looked like they might be thinner than the Mil Spec minimum, but maybe not.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 01-07-2017, 09:16 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Available HERE
Scott, the link you attach only show a revision 1 dated 5/1/14 on it. Do you have a new link?
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2020
Old 01-08-2017, 01:18 PM
That is the most recent one. Accessible from THIS PAGE .
It looks like the only change at that time was correcting some file formatting so that the .PDF was fully searchable so the rev dates wont necessarily match.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
