Old 01-06-2017, 09:28 PM
Billythekid Billythekid is offline
Default the ole 290 bump
any body ever put bigger cyl/pistons on a 290 lower end to bring it from 135 hp to 150 ish?
Old 01-06-2017, 11:40 PM
SHIPCHIEF SHIPCHIEF is offline
Yes it has been done, notably, Outlaw Engines, who does mostly airboats in Florida.
I have a T-18 with a low time, upgraded O-290-G that I would bore the cylinder spigots to fit O-320 cylinders, just to keep the special engine mount.
Plus, I think it would be cheaper than finding O-290 piston rings.
I have access to a milling machine, and plan to do it myself, otherwise, I would generally say no.
Even if the dollars made sense, the amount of time you might consume with the modification would be directly subtracted from flying time, always a bad choice.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 01-07-2017, 08:46 AM
N941WR's Avatar
N941WR N941WR is offline
FYI, ECI now Continental has rings for the O-290.
I have a set you can have. PM or email me your address and I'll end 'em your way.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-07-2017, 11:13 AM
Email sent!
The O-290 is powerful enough for my T-18, those rings could be very useful!
Scott Emery
2019
Old 01-07-2017, 11:25 AM
N941WR's Avatar
Originally Posted by SHIPCHIEF View Post
Email sent!
You are number 3 on the request list.
You would think I was proposing with all these people asking for a ring from me.
Bill R.
SC86 - Easley, SC
