01-11-2017, 08:01 AM
Help
All this is giving me a headache.
I'll need the N number for the DAR and plan to paint after a 25-50 hour period.
Can anyone list the font, contrast, etc that they use on the do-it-yourself site?
Just trying to keep it simple.
Hank
N14HN Phase 1
140268
B744
Sailplane Racing
Dues
01-11-2017, 09:17 AM
Have the vinyl cutting folks use this font -
http://www.dafont.com/amarillo-usaf.font
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-11-2017, 09:21 AM
1 - Select your size (I fly international a lot so went with 12")
2 - Select location (Along side the fuselage for me)
3 - Select font & color (I used Comic Sans (bold, italics), Gold with Black outline)
For details see post #7. I did a vinyl sticker 1st just to make sure I liked it, then had them painted on. YMMV
Not an RV, but you get the idea.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
01-11-2017, 01:40 PM
If it's just for the inspection and first few hours, go to Home Depot and buy some numbers, stick them on, and decide on the final version later. Or you could keep them on indefinitely if you like them.
Greg
Greg Arehart
N 7965A
01-11-2017, 01:58 PM
Greg
This is actually a really good idea. Just make sure they are 3" tall.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
01-11-2017, 02:04 PM
Originally Posted by Mark Albery
If you really want to know what the international rules for registration marks are, then you need to check out ICAO Annex 7
The US have filed a difference with ICAO so you are not required to have the under wing markings that most other countries require for their own aircraft.
So strictly, they should be 300mm high, un-ornamented and clearly contrast with the background.
Not quite, 30 cm is about 11.8 inches, but the ICAO text uses the words "at least .... high" so the US 12 inch marks are clearly OK under ICAO rules.
Strictly says a little bigger is OK, not the "should be".
Gil Alexander
01-11-2017, 04:16 PM
Great ideas....
Home Depot for the shake down,
Air Force sample to the painter.
When I tour Canada, vinyl temporaries.
Hank
N14HN Phase 1
140268
B744
Sailplane Racing
Dues
01-11-2017, 04:53 PM
Also remember if you put them on the fuselage, they may NOT be under the horizontal stabilizer. ref: ?45.25(b)(2).
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
