Old 01-02-2017, 08:43 PM
Peter M Peter M is offline
Default Carb heat shutter replacement
Hi guys - I'd appreciate your advice as I did not build my RV-6 and am struggling to find a replacement part.
In my RV-6 I have a carburetted O-360 installed. On the front of the airbox is a cable operated carb heat shutter. The shutter is attached by a piano hinge which is seriously worn and hole in the shutter arm that connects to the carb heat actuating cable is seriously flogged out (enlarged). Photos of the airbox and shutter assembly are available at:
https://dl.dropboxusercontent.com/u/.../IMG_1766.jpeg
https://dl.dropboxusercontent.com/u/.../IMG_1767.jpeg
https://dl.dropboxusercontent.com/u/.../IMG_1768.jpeg
https://dl.dropboxusercontent.com/u/.../IMG_1769.jpeg
What part should I order from Vans to replace the shutter and piano hinge? I think it's the "Filtered airbox - vertical draft" (http://www.vansaircraft.com/cgi-bin/...t=fab-vertical) but there's no detail about whether it includes the shutter and hinge:
Your advice would be appreciated.
Peter
ZK-VRV, Vans RV-6
Wellington, New Zealand
Old 01-02-2017, 09:09 PM
Peter,
You are correct - it includes all the parts including the glass box, shutter, lever, and a bunch of other stuff to make the complete box. Everything in yours looks pretty good except as you say the shutter and hinge.
You could order all of the kit, or just a piece of hinge. The shutter itself you just cut yourself to fit your glass box out of some .032 aluminum. If your lever could be re-used, you wouldnt need to get a new one of those either. You should be able to use the pieces as a pattern to make the new ones.
It shouldn't be a real tricky part to make and replace - as long as you have the tools to do it. Maybe you can find a builder near you for help.
If you need some pictures or more info, send me an email. I am doing my FAB now.
Good luck - have fun.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 01-03-2017, 01:51 PM
Thanks very much for your prompt reply. I'll get an order away to Vans today for the "Filtered airbox - vertical draft" and be happy in the knowledge that it will contain the bits that I need.
Peter
ZK-VRV, Vans RV-6
Old 01-03-2017, 02:03 PM
az_gila's Avatar
az_gila az_gila is offline
Post
That's a lot more parts and money than you need, especially after shipping it to your hemisphere.
If you have a builder nearby he'll probably have a scrap piece of 0.032 and a short hinge piece, and even build the replacement part for a few tinnies....
You should be able to re-use the control arm after removing the rivets. CORRECTION - looking at you pics, a new arm is needed, but it is simply a strip of alum. that is twisted to shape. Make a new one
PS are they still "tinnies" in NZ?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-03-2017, 03:54 PM
I sent you a PM. I will make a flap with hinge if you want.
rockwoodrv9a
Williamston MI
O-320 D2A
Old 01-03-2017, 07:35 PM
TJCF16's Avatar
TJCF16 TJCF16 is online now
I just finished replacing my carb heat door, Vans sells a kit which you get the hinge, metal for door, lever and rivets. You do not get the wire nut which you will also need because I am sure yours is worn. You may want to replace the air seal at the same time. I am not home or I would give you part numbers. But call Vans they will help you?
Tim Crouch
RV-9A N626TC
"Merlin"
Old 01-03-2017, 07:40 PM
Thanks Tim.
Rocky has offered to make me a replacement door and arm so I'm corresponding with him about that. However, if that doesn't work for some reason I'll give Vans a call.
Safe flying ...
Peter
ZK-VRV, Vans RV-6
Old 01-03-2017, 07:42 PM
Talking
Thanks Gil
No - "tinnies" is an Australian term and they're a bit further west than us. It's "cans" here
Peter
ZK-VRV, Vans RV-6
Old 01-03-2017, 09:37 PM
newt's Avatar
newt newt is offline
I had to do some maintenance on mine this year.
My RV-6 has the same arrangement as yours. The lever arm is held onto the shutter with two rivets, one near the centre of the shutter and one near the corner.
The rivet near the corner had sheared off. That put enough of a twisting load on the remaining rivet to turn it into a bit of a pivot point, so pulling the carb heat knob in the cockpit caused the arm to rotate aftwards around the center of the door, latching it in the carb-heat-off position.
The interesting thing was that the carb heat knob still had almost as much travel as it usually does, it just felt a bit "squishy" -- But pulling the knob was completely ineffectual, the carb heat system was unserviceable.
After grounding the aircraft, the repair was simple: Decowl, remove the FAB, drill out and replace the offending rivets, clean out the swarf, reinstall, check for proper function, go flying. A local SAAA member helped with the re-riveting (I'm a buyer, not a builder; don't have the right tools). The air filter didn't need to be removed from the carb.
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
