Old 01-02-2017, 02:48 PM
Smart_Solar Smart_Solar is offline
Default Couple of Lycoming questions
Interested in thoughts from our Lycoming guru's.
I am getting ready to build up an engine for a 6A. I have an AEIO-360-B1F with overhauled case and crank. My plan is to keep this simple with carb and a fixed pitch Sensenich prop. Does it make sense to use the AEIO crank in this application, or would it be better used in a more serious aerobatic engine build?
The crank P/N is LW-17141.
I will also be shopping for bearings shortly, I am curious if someone knows the reason for all the superseded Lycoming bearing P/N's? I see quite a few NOS bearings advertised, but also noted that they have been superseded.
Also figured I should try posting a picture - Here goes
Thanks in advance for your thoughts.
Old 01-02-2017, 03:05 PM
Raymo's Avatar
Raymo Raymo is offline
I tried posting your pic from the Amazon storage location but they don't seem to support this type of linking, that I can tell.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 01-02-2017, 04:58 PM
Thanks for the assist, guess I will need to find another location for the pictures to link from.
Old 01-02-2017, 05:21 PM
N941WR's Avatar
N941WR N941WR is offline
Why wouldn't you want the acro crank, even if you are going to install a FP prop? You can punch (or remove) the inner seal and install the outer seal (search for it) and run a Catto.
Then, should you ever want a CS prop, you can install one. Also, it is a good selling point to be able to install a CS prop, should a future buyer want one.
The question about the bearings may simply be the material they are made out of. I really don't know but that would be my guess, and it is only a guess.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-02-2017, 05:25 PM
6 Gun 6 Gun is offline
Smile Bearings
Talk to aircraft specialties about bearings and machine work best prices Ive found.
Bob
Old 01-02-2017, 05:38 PM
I have been spending some time on Aircraft Specialties site, lots of great info. Glad to hear that their pricing is good. Just more of a curiosity on the upgraded bearing P/N's, figured there must have been a reason.
Old 01-02-2017, 07:32 PM
scsmith scsmith is offline
If you really want to go the simple route, you might consider exchanging or selling that AEIO. Some people would prize that, and would be willing to pay a bit of a premium.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 01-02-2017, 07:35 PM
Default Bearings
It might be part numbers from the three different companies, ECI Lycoming and Superior Air Parts also there sold STD. M003 ect.
Bob
