Old 01-21-2007, 04:17 PM
tx_jayhawk tx_jayhawk is offline
Default AN5812 Pitot Tube Screw Size?
Does anyone know the right screw size for the standard AN5812 pitot tube attach holes? It seems to be smaller than a #6, but bigger then a #4. M4 doesn't seem to work either?
Does anyone know what it should be?
Scott
7A Finishing
Old 01-21-2007, 04:30 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Scott
7A Finishing
I just happen to have an AN 5814-1 sitting in a box, on this computer desk. The instructions for this (14) model, show four 10-32 size screws.
Old 01-21-2007, 04:44 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Most pitots use 6-40 (fine thread). I don't know why they picked this very uncommon size. I re-tapped mine to 6-32. Works fine.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 01-21-2007, 07:08 PM
Thanks guys. Anyone know a readily available (local) source of 6-40 screws? I think that must be the size of my tube.
Did it not ruin the thread entirely to tap it out to 6-32?
Old 01-21-2007, 11:24 PM
rv6ejguy's Avatar
Nope look fine. Still holding in my 6A built 4 years ago too. I did not drill to tap size.
Old 01-22-2007, 07:39 AM
tsneidin tsneidin is offline
I just went through this problem. I found and ordered the 6-40 screws here:
http://www.aerocraftparts.com/default.aspx
Todd Neidinger
9A-Fuse
