Old 12-31-2016, 10:50 AM
Steve Melton's Avatar
Default 3D printed side pocket
I have a metal side pocket that is simply an "L" shaped alum piece. Sometimes it is a pain to get something out of the corner or a piece of paper falls thru. it's not a big deal but could be better. I'm working on my 3D skills and made a printed side pocket with angled access and big radii at the bottom, weight = 160 gm.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 12-31-2016, 11:07 AM
kentlik's Avatar
kentlik kentlik is offline
Looks great. Heavy wall thinkness. Is the material ABS or Polycarb?
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 12-31-2016, 11:17 AM
the mat'l is PLA. my first print. will try some other material when the design is final. the big radii at the bottom are printed with 30% infill to reduce weight. I think I can get the overall weight down from 160 gm to 120 gm.
Steve Melton
Cincinnati, OH
Old 12-31-2016, 11:24 AM
sblack sblack is offline
That's really cool. Nice job.
There is a video on the eaa hints for homebuilders site by the guy from Rainbow Aviation that shows dozens of cool parts made with a 3d printer.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 12-31-2016, 11:46 AM
DaleB's Avatar
DaleB DaleB is offline
Steve,
That's a pretty good sized piece. What kind of printer do you have?
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-31-2016, 11:49 AM
it's a TAZ6 and this piece just fits on the diagonal. this piece is 14.25 inches long.
Steve Melton
Cincinnati, OH
Old 12-31-2016, 01:41 PM
Terri H Terri H is offline
Very nice!
Terri H
RV-6 Slider,
IO360-M1B, BA Hartzell
Old 12-31-2016, 04:32 PM
Steve, you answered my question. I was pretty sure it was a TAZ. Great printers!
Nice project for your RV!
Old 01-01-2017, 05:25 AM
dtw_rv6 dtw_rv6 is offline
The part looks really good, but you may find that PLA will start to sag if your airplane spends any time out in the sun.
The materials with higher glass transition temperatures like ABS and Polycarbonate are a little trickier to print with, but the parts are much more robust than PLA.
The downside is that I've had to build a heated enclosure around my printer before I could get anywhere with ABS. Polycarbonate requires much higher temperatures than even ABS - chamber is 70C, bed is 140C, and nozzle is up around 285C. ABS works with a bed temp around 110C with the same heated chamber.
These are not firm numbers - they are highly dependent on the specific filament formulation and your printer rigidity/speed capabilities.
Don
Old 01-01-2017, 05:58 AM
SabreFlyr SabreFlyr is offline
Maybe consider the PLA piece to be your prototype and, when you've got it the way you like it, send your file off to one of the print houses to be printed in ABS or PC.
Ray Dosh
LJ45 driver
RV-14 QB #140212
Tail feathers finished
Tail cone in progress
2020 DUES PAID
Marion, IN MZZ
