Old 12-20-2016, 03:26 PM
rwarre rwarre is offline
Default best ear buds and placement
Recently purchased the Halo headset. Having trouble eliminating the low frequency and thought it might be either the wrong ear bud or how I put them in my ears. Anyone have any procedures that work on getting a good fit or ear bud preferences? Thanks
Old 12-20-2016, 03:37 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I find the plain yellow foam work best.
More often the problem is not having them fully inserted.
The technique of pulling the ear lobe back while pushing them in takes a little practice.
Also make sure they're warm and dry - not always the case if you leave them in the cockpit!
Old 12-20-2016, 03:45 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Same experience here until I found this video by QT. Problem solved for me.
https://www.youtube.com/watch?v=f6SGPdJnJUI
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 12-20-2016, 04:36 PM
I found the stock yellow foamies to be very good, but opted to have a set of custom plugs moulded earplugs. These have worked out very well for me. Low frequencies are very nicely attenuated. Costco will pour the custom ear moulds.
Old 12-25-2016, 01:57 PM
rv7charlie rv7charlie is offline
Airtight fit in the ear canal is important for effective noise reduction. Custom molded plugs can work but there's no guarantee until you try them. My canals change shape when I move my head, so I need flexible plugs to keep the canals sealed. The silicone plugs don't block quite as much as the foam, but seal well for me and are the easiest to insert.
FWIW,
Charlie
Old 12-25-2016, 02:54 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
I use the jumbo size yellow foam and replace them often. They work better warm. Put a set in your pants pocket on a cold day and install when ready.
Here's where I found them from past posts.
http://www.etymotic.com/auditory-res...ries/er3c.html
Bruce, Katie, Hana and RV-8 HulaGirl
Old 12-25-2016, 03:19 PM
springer springer is offline
Originally Posted by rv7charlie View Post
The silicone plugs don't block quite as much as the foam, but seal well for me and are the easiest to insert.Charlie
My experience was just the opposite. I couldn't get the foam to work plus they got dirty "rolling" them to fit. I was about to sell mine until I tried the gray silicone ones. Happy camper now.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
