  #21
Old 12-20-2016, 04:43 PM
I just bought a Van's fuel tank test kit for a friend. It's pretty lean; some builder stuff required. Larry, you ought to offer your kit on the market - it's a very, very good kit. Seriously.
I have the deluxe locking tank caps. Mine leaked through the center stem. I friend sent me some Fuel Lube, this stuff. It did the job. I recommend the 5 oz. tube. It'll be enough for several lifetimes.
Dave
Old 12-21-2016, 03:28 AM
Z-EDD's Avatar
Z-EDD Z-EDD is online now
Originally Posted by rzbill View Post
I am pretty sure I have seen that Vans is now pre-cutting the landing light hole in the wing skin. That's fine if you want the landing lights in the position they have selected. (mine are in the tips).
Man I hope not! But at least a couple of years ago they weren't. They ARE cutting the leading edge for the stall warner access though.
Regarding flop tubes, consider the following. If fitting the float senders they must be moved to the next bay outboard and installed through the rear baffle. In this position they will read neither completely full, nor completely empty, not such a big deal.
HOWEVER, if you ever need to access the senders for maintenance, even just to fix a bad connection, the tank will have to be removed from the wing! A major Pita.
Capacitive senders would solve this but vans must have discontinued the kit for a reason. This is just a guess, but it could be to do with maintenance down the line. A bad connection inside the tank would be really hard to fix.
Are you looking for a heated pitot or do you just want AoA? If the latter then there are other ways to accomplish this than the expensive pitots from Dynon or Garmin. Most any tube or hole pointing down at an angle of ( I think) 30 degrees from horizontal will do the trick. See the following thread
http://www.vansairforce.com/communit...ad.php?t=34040
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
Old 12-21-2016, 09:59 AM
rv8ch's Avatar
rv8ch rv8ch is online now
Default Angle
+1 on the angle - get more than you think you will need in all thicknesses.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-21-2016, 10:17 AM
CubedRoot's Avatar
CubedRoot CubedRoot is online now
Added the extra W-730 aileron jig to the list.
I am planning on using a heated Pitot/AOA but have not decided on which pitot mount yet. Either Gretz or the one Dynon sells.
I've still got a few days before I get the order in, since the price increases are not done yearly anymore. I may want until after the holidays to order the kit.
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
Old 12-21-2016, 10:21 AM
Price increases generally seem to happen sometime in the middle or late in the first quarter.
Dave
Old 12-21-2016, 08:35 PM
Draker's Avatar
Draker Draker is offline
Originally Posted by nilberg View Post
Things to consider:
Get the RV7/7A drawing DVD, it has all the OP drawings as well. Including the capacitive drawings (OP07). Pretty easy to make.
Anyone have an idea why Vans stopped selling the capacitive fuel level senders? From what I read they seem to be superior in several key ways. There must be a reason they aren't sold by them anymore.
Old 12-21-2016, 10:13 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Default Mark those extra angle pcs
+2 on more angles. You will need them eventually for all sorts of things. Braces, mounting instruments, etc. May I suggest that as you inventory the parts, figure out which angles belong in the kit and mark the others you ordered as extra or "stock material" From what I remember, some that came before cannibalized kit parts, not knowing they were part of the kit, and had to order more. The longerons should be obvious, but then that is in the fuselage kit down the road. The fuse kit has lots of angle that can be confused with "in stock" angle you order now.
VAF# 835
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
2020 Dues Paid
Old 12-27-2016, 07:04 AM
cczarnik cczarnik is offline
Newb here reading with great interest- I'm almost ready for the wing order too-
Question- why the extra longeron a with the wing? Aren't these fuse parts and extras can be ordered then?
Also, are there any parts on the wing with a high probability of a re-do? It would have been nice having my second set of front spars in the emp kit- and the extra trim tab
Chuck
7a emp complete, wings underway
VAF Dues paid - 2018
Old 12-27-2016, 07:51 AM
RV6_flyer's Avatar
The Fuselage Longeron ships with the Wing Spar.
The cost to built another box that long would increase crating cost a lot therefore it is more economical to just include the LONGEST part of the airplane project with the wing kit that also has the 2nd longest part.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 12-27-2016, 07:55 AM
wirejock's Avatar
wirejock wirejock is online now
Default Longerons
The wing spar crate is made long enough to ship both the wing spars and the fuse longerons. Vans ships the fuse longerons with the wing kit for that reason as it saves shipping costs to the builder.
Most builders have fewer problems with the wings so no need for re-do parts. The suggestions i this thread are a good reference.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
