Old 01-20-2007, 11:51 AM
larry G larry G is offline
Default Fuel tanks
I have my fuel tanks all done with no leaks. Does any one prime the two end ribs and baffles before they install it on the main spar.
Old 01-20-2007, 12:03 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default I did...
...since I've decided to primed pretty much everything, I went ahead and did so. Was it worth it? Maybe I'll let you know in twenty years or so!!
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 01-20-2007, 04:26 PM
RV8N RV8N is offline
I primed the whole tank... skins, end ribs, back bulkhead... everything.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 01-20-2007, 05:59 PM
osxuser's Avatar
osxuser osxuser is offline
Same as the rest of the airplane. Up to you...
RV4 wing in Jig @ KPOC
RV7 emp built
Old 01-20-2007, 07:00 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
If your end ribs are a little messy with proseal like mine, primer hides some of it!
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 01-20-2007, 07:39 PM
Jamie's Avatar
Jamie Jamie is offline
Not to beat the dead primer horse again....
but what primer did you guys use on the inside of the tanks? Just curious as the construction manual explicitly warns against doing that.
Old 01-20-2007, 07:48 PM
Default None!
Actually, I wimped out and had my tanks built by Evan Johnson. I'm pleased to say that he didn't primer the inside though! After I fitted everything to the wings, I primered all the outside ribs & rear baffle (not the main skin yet) prior to re-installation.
Jeff Preou
Old 01-20-2007, 09:26 PM
I don't think any of us (except maybe Karl?) are talking about priming anything except the outside of the end ribs and outside of the baffle.
Steve M.
Ellensburg WA
Old 01-21-2007, 11:19 AM
osxuser's Avatar
I highly suggest AGAINST priming the inside. Fuel reaction on primer could be unknown, and proseal doesn't stick to primers as well. Both these could lead to leaks later, and potentially clog screens later on too.
RV7 emp built
Old 01-22-2007, 07:19 AM
Absolutely DO NOT prime the inside of the tank. I was trying to say that I primed the entire outside of the tank before mounting it on the wing. I did this because I live on the Texas gulf coast... lots of salt air around here. I primed everything on the plane... with the exception of the inside of the tanks.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
