Go Back   VAF Forums > Education > Flight Testing
  #11
Old 12-17-2016, 05:19 PM
snopercod's Avatar
Default That's what I was worried about.
Likely a very thin layer of ice is my guess.
That's what I was concerned about. I've never flown in icing conditions and don't know what it looks like (other than photos). Neither did I know that one could experience icing in clear weather. My laminar flow airfoil doesn't tolerate icing well so I was real concerned. I didn't notice any degradation in my 165 Kt TAS at the time so I just shrugged and pressed on. I reviewed the ATC audio from my Garmin Virb and they were reporting a -1 deg C dewpoint on the ground. Thanks for your opinion.
(2020 dues paid)
Old 12-17-2016, 09:27 PM
If your OAT is accurate, it is very unlikely you had icing at +5 C.
Old 12-18-2016, 06:53 AM
snopercod's Avatar
Default OAT calibration unknown
Originally Posted by BobTurner View Post
If your OAT is accurate...
I guess I need to do a single-point calibration check on my Davtron 5-in-1 to find out. Dipping the probe in some ice/water mix shouldn't be too difficult. That will give me something to do while I'm suffering through all this non-flying weather. Thanks for the idea.
(2020 dues paid)
Old 12-18-2016, 07:07 AM
sblack sblack is offline
The temp on the LE will be considerably lower due to the low static pressure at that location.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 12-18-2016, 08:40 AM
runt runt is offline
Default Not convinced it's ice
I assume we are talking about the white area on the leading edge.
I have seen plenty of icing and that doesn't really look like icing. Notice how it doesn't come all the way to the root for one thing. It looks to stop about half way. Ice would be on all of the leading edge. The air in Colorado is pretty dry. Doubtful you would collect ice in that flight condition from what I'm seeing in the photo.
Again, if we are talking about the white area I would guess it's a reflection of the clouds in the distance. Light does funny things.
The plane I normally fly has heated (shiny) leading edges. When we go through clouds and the light is right you would swear there is a layer of ice when in reality it is simply a reflection.
Hard to say based on that picture.
Did it disappear all at once? Ice would break off in sections.
Old 12-18-2016, 09:05 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Just as a point of fact: aircraft icing will indeed break off in sections particularly as it starts to melt. However, if it remains frozen while flown through clear dry air, it will tend to sublimate. Clear air sublimation is the conversion of matter from a solid (ice) directly to a gas (water vapor). Happens faster in jets, but more slowly in slower aircraft because slower speeds lesson the wind/ice friction.
I now return you to your originally scheduled topic. I can't tell what your photo is showing, sorry.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 12-18-2016, 10:31 AM
Lower, yes. 5 C (9 F) lower? Unlikely.
Old 12-18-2016, 03:08 PM
brad walton brad walton is offline
I've always thought of a change of state from solid to vapor as being sublimation
Old 12-18-2016, 03:23 PM
scrollF4's Avatar
Yep, you're right. Corrected.
Scroll
Exemption waived.
Old 12-21-2016, 11:47 AM
snopercod's Avatar
Default OAT calibration OK
This morning I did a single point calibration of my OAT sensor/display. I dipped the probe in a bath of crushed ice and water, and the Davtron indicated 32F/0C. My Fluke read 32.1F. At ambient the Davtron read 43F and the Fluke read 43.1F. So the 5C reading was probably accurate. BTW, my OAT probe is located under the wing, well away from the cowling exit air. I wish I had known about Skew-T charts last year
(2020 dues paid)
