  #11
Old 12-13-2016, 06:17 PM
Captain_John's Avatar
Originally Posted by olyolson View Post
Amir,
I recently had my engine overhauled and removed the Wolverine oil pan heater that was on it. I installed a new one and you can have the old one for postage cost. You will need to find compatible adhesive to attach it to the oil pan. I'm sure if you contact Wolverine they can send you a tube of adhesive. PM me with your address and we will coordinate details for shipping.
Oly
Call them and talk them up.
They are very accomodating!
CJ
The experiment works!
Old 12-13-2016, 07:04 PM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Wow thank you for all the feedback and especially thank you Oly for the offer. I just bought a Switchbox from a fellow VAF member and looking forward to hooking it all up and getting my plane heated while I drive 40 minutes to the hanger early Saturday mornings... So exiting
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 12-13-2016, 07:13 PM
Toobuilder's Avatar
Just as a data point, I would plug my 300w heater in the night before flying and throw a blanket over the cowl and seal the inlets. After 12 hours or so, it was nice and warm, but I never once worried that it was going to get "too hot". The engine is 500 pounds of metal (with cooling fins, no less)...
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 12-13-2016, 07:56 PM
Scbado Scbado is offline
Default Reiff
Originally Posted by larrynew View Post
I installed the Reiff oil pan heaters recently and here this is why I went with them instead of the much less expensive ones I found.
  • While researching, I literally had bad dreams about the cheap ones catching fire. Rational concern? Don't know but if helps me sleep better...
  • Included thermostat with a 190 degree cutoff
  • I think the aluminum construction will last much longer
Probably not needed in central Texas but it sure is nice to start a warmed engine. Also, planning winter trips to Kansas.
I 2nd the Reiff. I have been using mine for years with no issues. On the Reiff system you can also get the cylinder band heaters also, which I highly recommend. Lots of money invested behind that big fan. I want my engine to warm and happy.
Jerry Roeder
C150 N222PA at 02C
RV-9A Standard Build Slider
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Moved Project to 57C
Old 12-14-2016, 03:16 PM
flightlogic's Avatar
Give it a bit more than 40 minutes !!!
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
