Old 12-12-2016, 09:00 AM
Michael Burbidge Michael Burbidge is online now
Default Intake tube flange torque...
I have an intake leak, as many have had. I'm replacing the gasket. I cannot find a torque value in the overhaul manual for the intake flange bolts. So I'm assuming that I use the torque for 1/4-20 which is the bolt and thread size. That value according to the overhaul manual is 96 in-lbs. Is that correct?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 12-12-2016, 10:20 AM
jrs14855 jrs14855 is offline
Default Torque
That is correct. Unless otherwise specified all Lycoming torque values are derived from the standard chart.
