Go Back   VAF Forums > The Never Ending Debate Section > Primers
  #21
Old 12-16-2016, 05:23 AM
6 Gun 6 Gun is offline
Smile Boomer
You guys be careful to rinse your parts good of any cleaner that's soap as its a release agent.
Bob
Old 12-16-2016, 07:11 AM
brad walton brad walton is offline
I agree with all Sam said except that Variprime is not a two part epoxy. It is a two part self etching primer which adheres extremely well. I clean with thinner before use and a maroon Scotch Brite pad.
Old 12-16-2016, 08:07 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default SEM
Originally Posted by majuro15 View Post
Give SEM self etching primer a shot if you can get it shipped reasonably. It's a rattle can that goes a long way and is really durable. It's about $20 USD per can, but a lot easier than having to mix and spray then clean equipment. I've found good deals on Amazon.
SEM is a really great product and worth the money. Dries very fast and is
extremely durable. Great for aluminum, not so on steel. Epoxy primer for steel
And high wear areas.
Al Girard, Newport, RI
N339AG
RV-9
Old 12-16-2016, 09:24 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Originally Posted by Boomer506 View Post
I mix it about 2 parts accelerator to 1 part primer. And will thin a bit more if it thickens in the pot during application, or if I need to stretch it a bit to complete whatever I am priming. For me it seems like the important thing is that it be thin enough to flow out well after the sponge brush stroke, so you don't get any brush marks. Yes, it is a 2 part epoxy, but I have found that over thinning doesn't seem to interfere with curing or durability.
Careful using more accelerator (DuPont actually calls it a converter) since that is the part that contains the actual acid ingredient - phosphoric acid.
It thickens quickly since a lot of the rest of the converter component is a blend of solvents, and that is probably what overcomes small fingerprint spots you mention in your first post.
It is not an epoxy so extra converter is simply adding more acid and rapidly evaporating solvents to the mix.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-16-2016, 06:57 PM
1001001's Avatar
1001001 1001001 is offline
For some parts I have also been sponge brushing primer. I am using the Sherwin Williams Sherwin-Williams CM-0724400 chromate primer. I mixed it at normal spraying strength for the first brush coatings but I will probably try reducing it next time to minimize some issues I had with inconsistent thickness.
Old 12-19-2016, 05:01 PM
RV7ForMe RV7ForMe is offline
Default Is this what I am trying to stop by priming?
Corrosion?
VAF dues paid for 2020
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 12-19-2016, 05:18 PM
maniago's Avatar
maniago maniago is offline
Looks like filiform to me. To answer your question directly, yes.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 12-19-2016, 05:21 PM
I am sorry, What does filiform mean?
Old 12-19-2016, 05:44 PM
maniago's Avatar
Take a quick google on filiform corrosion aluminum. Also take a look at Ch6 of AC43-13 which you can download for free. Its a good treatise corrosion and corrosion mitigation wrt aircraft (just one of the fed works on corrosion) Not the be all and end all, but a good starting point. Doesnt cover some of the ACF, Corrosion X post build type of remediations/mitigations in use these days however.
BTW noone learns about corrosion until they come across it, so dont think youre behind the curve or anything. I didnt know anything until I found some corrosion pits on my wing spars. Then someone else showed me the references and such. Yea for VAF!
Mani
N251Y (res)
Old 12-20-2016, 11:46 AM
Boomer506 Boomer506 is offline
Originally Posted by DaAV8R View Post
Sam........do you plan on top coating the Variprime? I have been using Nason self etching primer, a cheaper Dupont primer. It doesn't go on as good but has a similar appearance. I had planned on shooting a finish coat but I like the look of the primer. Just curious what your plans were.
I do not plan to top coat the variprime inside the airplane, except for the panel, throttle quadrant and C/B and switch panel as shown in the picture. The top coat on those items is DuPont single stage Imron (now called Axalta AF400). The exterior will have a top coat, but I am still not sure how I am going to approach that. The variprime will need to be re-activated somehow. I might just clean/degrease and spray on a second light coat of variprime before the top coat.
Sam Bovington
Intruder B/N, Stanwood, WA
RV-6 N934B built, flown and sold
PA-23-150 N2108P restored flown and sold
RV-8 "Bad Blue" under construction
