Landing light used as taxi
I have a set of aero led Sunray plus, 1 in each wingtip. I was thinking about using a three position switch up landing, middle off, down taxi and running the taxi circuit through a preset dimming module to the sunray plus lights to dim them a bit so as to not blind any one on taxi way. Just need for recognition. Any thoughts on this? Seems to be a good solution so we don't have 2 sets of lights, cost and maintenance. I will be using the vertical power ECB, so should need some diodes or could run though relay so as to not back feed the landing light or taxi circuit.
