Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 01-21-2007, 08:46 AM
vlittle's Avatar
vlittle vlittle is offline
Originally Posted by az_gila
Actually, it's 157 HP at 2600 rpm per the Lycoming O-320 Operator's Manual... (98.1%)
gil in Tucson ... who likes real numbers...
Actually, Lycoming has different numbers for different O-320 models. The -B amd -D series show about 159.5 HP at 2600 RPM, sea level power. I think Superior's data is similar.
Lycoming's D2J model shows 155 HP at 2600 RPM.
Finally, the reality of the typical RV installation, is that you'll a bit of MAP boost due to ram air affects on the intake. My calibration data shows that this gives about 3-4 HP.
Bottom line? You may actually be seeing more than rated HP.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 01-21-2007, 09:03 AM
az_gila's Avatar
az_gila az_gila is offline
Question Versions - curves?
OK Vern.... now I'm confused....
My O-320 Lycoming Operators Manual has two applicable figures for 160 HP versions.
Both are titled Sea Level Power....
Fig 3-5 "Sea Level Power Curve - O-320-B and -D series"
and
Fig 3-14 "Sea Level Power - O-320-D1D"
The first one is t 157 HP I quoted, the second one shows about 155 HP @ 2600 rpm, and is a version with a horizontal HA-6 carb.
The pages have a revision date of Jan, 1977.
Am I looking at the curves wrong? are these the correct curves? or do I have old data?
The two curves quoted above have 160 HP at 2700 rpm as a marked point (makes sense... ...)
gil in Tucson - more inconsistent Lycoming data?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
