Old 12-01-2016, 02:13 PM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
Default When do I need to have an official DAR inspection?
I am about to finish up my horizontal stabilizer, and before I rivet on the rear spar I want to make sure I don't miss any chances for an inspector to take a look.
I am in the US, and I plan on applying for the repairman certificate once this plane is done. However, I am not 100% sure on when I should have inspections done to appease the FAA to get an airworthiness and repairman certificate(s).
Does a DAR come out an inspect the plane when its near flight ready and issue the certificate then? Or do they need to come out periodically during the build to "sign-off" on your progress?
I am planning on having an EAA tech counselor come by before I rivet on the rear spar, to make sure I am on track and doing things right, but I am looking for clarification on what needs to be done for the official FAA inspections.
Thanks!
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
Old 12-01-2016, 02:18 PM
Raymo's Avatar
Raymo Raymo is offline
I am nearing completion of my -7A and will soon be scheduling an inspection. I've been told that the DARs in this area only confirm the paperwork is correct.
I've not heard of any DAR doing in-progress inspections but you might find one that is willing.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 12-01-2016, 02:24 PM
vic syracuse vic syracuse is offline
Super Moderator
I don't know where you heard that DAR's in this area only do paperwork inspections? I am from Atlanta (I see you are in Georgia), and I assure you that I do more than a paperwork inspection. So don't hesitate to give me a call, assuming you would like a thorough inspection.
I have also done many "in-progress" inspections for those that ask. And it is so easy today to use FaceTime and be able to discuss any areas of concern along the way.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 12-01-2016, 02:34 PM
CubedRoot's Avatar
I am wanting someone to look this thing over thoroughly and tell me of any deficiencies, before I put my life in it. Personally, I am trying to build a superior quality airplane, but I also realize I am a new builder and will probably make mistakes.
I am wondering what the process is to have this airplane get its certificates, and if there is any points in the build where I need to pause working so that I can have an "official" FAA inspection done (if any are even required during a build).
However, since I want to build the best possible plane, I would like to have as many eyes on it as I can to let me know if I am on the right rack.
Vic, I am not too far from you up in the Chattanooga / Ooltewah area! Do you do inspections this far North?
Lynn Dixon
RV-7 Slider -
Old 12-01-2016, 02:48 PM
Raymo's Avatar
Vic
Vic,
You and I met at 3J1 last year (I drooled on your RV-10 ). The DAR(s) in question are in the SE South Carolina area - Columbia and/or Charleston.
Sounds like you have another customer in TN now
Ray
Old 12-01-2016, 03:01 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
There are others, like Vic or Mel, who know much more than I do concerning your question. However, I will say that having built two planes and had them signed off both times by an FAA inspector I can tell you they are going to come out, inspect, and sign off whenever it is you decide the thing is close to being ready to fly and you fill out, and send in, the appropriate forms. You most certainly can get "in progress" inspections by anyone who will agree to do so but it is not a requirement to have an FAA inspector or a DAR do so prior to the final airworthiness inspection.
Just a note for any Canadians reading, this info applies to US inspections. I am aware there are different requirements for you guys up north.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 12-01-2016, 03:11 PM
CubedRoot's Avatar
Excellent. So it sounds like the "bare minimum" would be to get the plane ready to where I think is near flight ready, do the paperwork, and have the DAR come out and inspect.
But, ideally, what I should do is either get a DAR to come out periodically during the build to check my work, OR, get a reputable EAA tech counselor to look over the work periodically. This way I can get some assurance I am not jacking up my plane, get some good advice on how to do things and also fix any mistakes that would cause me to fail the actual final DAR inspection while they are easy to fix (during build progress).
Lynn Dixon
RV-7 Slider -
Old 12-01-2016, 03:14 PM
Super Moderator
Yes, I do inspections in Tennesse, N & S Carolina, Florida, Georgia, Mississipi and Alabama and would be honored to do yours.
Vic
Vic Syracuse
Old 12-01-2016, 03:39 PM
rvbuilder2002's Avatar
What you are looking for is an EAA Technical Councelor.
Google it for more information.
This is the exact reason that they exist.
I suggest you find one specifically with a lot of experience with RV's.
Scott McDaniels
Hubbard, Oregon
Old 12-01-2016, 04:21 PM
skylor's Avatar
skylor skylor is offline
Default EAA Tech Counselor
It sounds like what you are really looking for is to have an EAA Tech Counselor come out and do a progress inspection. When I was building, I was fortunate enough to find a tech counselor that was also a DAR.
Skylor
Oops, I didn't see Scott's reply before hitting send on my own...
