Go Back   VAF Forums > Main > Safety
Old 11-29-2016, 10:09 PM
jpowell13 jpowell13 is offline
Default Thanks Ben
Thanks to Ben Fraizier for the letter regarding wrapping exhaust pipes. Seems like most of the airplane fires I hear about are exhaust related. Just witnessed an SR22 being extinguished due to an exhaust leak on the ramp at BTR. Thankfully, the young ladies (pilot and passenger) were preparing to fly back home to TX and the fire started while they were still on the ground. John
Old 11-30-2016, 05:42 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default exhaust
I agree.
The more experience I get at maintenance, the more I watch and maintain the exhaust system.
Clearances, heat shields, anti-seize the joints etc.
Early on I fell for the wrapping thing and had problems.
Luckily, Larry Vetterman fixed me up and set me straight.
No Wrapping!
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 11-30-2016, 03:28 PM
RKellogg RKellogg is offline
Arrow Huh??
I am all for safety, and fires in cowls are bad.
But there are many variables in the system. The method of exhaust pipe support (or lack thereof) may be more critical to header pipe fatigue. Roll frequency vibration is significant on flat fours.
Did the SR-22 mentioned as 'proof' have a wrapped exhaust? Never seen a wrapped Cirrus exhaust... Web search found pictures of cracked Cirrus exhausts, but none wrapped.
Without the ability to cross-examine partial data, one cannot draw meaningful conclusions.
The horizon beckons, I must fly.
- Roger
Old 11-30-2016, 03:40 PM
SgtZim SgtZim is offline
You may be right - more data may be needed, but it does make sense to me. If you insulate the exhaust pipes, they will reach much higher temps, and the cooling is slowed after shutdown - possibly annealing the metal. - I'd keep a close eye on them if you have insulated them.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
