Proximity of strobe wiring to my FPS system
I have the FPS system to install in my RV 7 and when I read the instructions it suggests to keep strobe and radio wiring seperate from the trim and elevator servo wires to the FPS system.
I used shielded cable to the strobe and nav light back there.
Unfortunately, I have to run the FPS Flap system wires under the seat along with the wires for strobes and nave lights.
My Question is have any of you done this and experienced problems with the FPS system as a result?
Second question, I have read here many like the FPS system of flap control and wonder if any of the newly installed have had concerns on programming and test flight with the system.
Thanks for all response
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
