Old 11-26-2016, 05:30 AM
rjcthree's Avatar
rjcthree rjcthree is offline
Default An A&P/AI question: which logbook?
Is there a rule or rule of thumb that defines what goes into an engine vs an airframe logbook? Some things seem like they could go in either, like fuel lines from the collator to the fuel pump; its bolted to the engine, but part of the fuel system arguably. Likewise EGTs sensors, bolted but the engine could care less. One step further, even the alternator is in the grey zone. Any thoughts on the grey zone would help. Thanks.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
Old 11-26-2016, 06:04 AM
catmandu's Avatar
catmandu catmandu is offline
More qualified answers will follow, but my guy says his rule of thumb is if the engine requires the item to run, you put it in the engine book.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 11-26-2016, 06:20 AM
Mel's Avatar
Mel Mel is offline
Default Basic rule of thumb......
If it would go with the engine, if sold separately, it should go in the engine logs.
Nothing says it can't go in both logbooks.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-26-2016, 07:33 AM
cajunwings cajunwings is offline
Default Which log
If you take your engine off and send it out for overhaul everything left behind is technically airframe parts. This includes starter, alternator, exhaust, baffles, cowl & spinner, lord mounts ect. I agree if it's a close call it should go in both books.
Don Broussard A&P, IA, ATP
RV-9 Rebuild in Progress
57 Piper Pacer
Old 11-26-2016, 08:26 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Thumbs up
Thanks Don. For some reason, when you said it in those words, its easy to make a logbook distinction.
57 Piper Pacer
Old 11-26-2016, 09:05 AM
Jesse's Avatar
Jesse Jesse is offline
There certainly is a gray zone. Alternator, I would out in the engine logbook. Egt sensors I would out in the airframe logbook because the instrument is I side. Baffles I would out in the engine logbook. Fuel system I would out in the airframe logbook if it is firewall aft. Firewall to engine I may put in both, but certainly in the engine logbook.
Jesse Saint
Old 11-26-2016, 09:51 AM
rvbuilder2002's Avatar
This is the standard that most professional mechanics and shops use.
Scott McDaniels
Hubbard, Oregon
Old 11-26-2016, 02:37 PM
snopercod's Avatar
Default Oil changes?
How about oil/filter changes?
(2020 dues paid)
Old 11-26-2016, 03:28 PM
Default Logbooks
Oil & filter changes, spark plug cleaning, gapping or replacement, mag work or timing adjustment, carb or fuel injector inlet screens and engine gasket replacement are examples that are commonly entered in the engine log.
1957 Piper Pacer
Old 11-26-2016, 03:56 PM
For me, if a part is in the engine parts manual, I use the engine logbook. That'll work for my RV-3B when it gets done, too. On my certified plane, I put whatever's in the aircraft parts manual in the airframe logbook.
The prop has its own logbook, an additional one.
Dave
