  #11
Old 11-25-2016, 03:08 PM
WAM120RV WAM120RV is offline
Default Thanks Bill Repucci
Bill
Thanks for clarifying this, so bottom line is that this would not have happened if V40 had been installed?
In which case it still makes sense to check your leads, but the potential problem has already been sorted by EMagair, provided the mags are upgraded to V 40?
If any of you have not realised Bill is a great asset to this board!!!
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 11-25-2016, 03:12 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by WAM120RV View Post
Bill
Correct, or as correct as I understand the issue and the solutions we have helped others work through can be.
The real answer is that Emag (the company) has the final say on what does and does not work with their P-mags (the product), not some guy who makes a bolt on (The EICommander) for them.
I'm not so sure about that, but thanks!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-25-2016, 03:33 PM
judoka5051 judoka5051 is offline
Default Title is pertinent!
I have to agree with the poster about the choice of title for a couple of reasons. First, It will alert P-Mag owners to a potential emergency, and motivate them to get the update. Secondly, The P-Mag is supposed to be a drop in replacement for a standard mag,,, with the understanding that a loss of power is an inconvenience, not an emergency (at least in the sense that you're not going to enjoy a forced landing).
BTW, I put them in the 8A I built and loved them. So, I'm not against EI at all. In fact I'll be using the EFII in the new plane, primarily because I wanted single lever fuel injection too.
Lance Logan
McAlpin, FL
Plane at FL10
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
Cherokee 180 pickup truck
RV8 Fastback
Old 11-25-2016, 04:07 PM
Larco's Avatar
Larco Larco is offline
[quote=N941WR;1129539]I can't stress enough how important the Version 40 upgrade is!
Yes, that is what this means.
It turns out that pre-version 40, when the P-mags are powered (or spinning above 800 RPM) and they are grounded, they are in setup mode. Which means two puffs in the manifold line will change their TDC mark to wherever the crankshaft is when the P-mags get the puffs.
With the shorting described by the OP, the system was being grounded, which puts it in setup mode. (Powered but grounded is setup mode.)
When your intake valve closes there is a short duration but high velocity positive pulse in your manifold pressure line, just like the puff it takes to set the timing.
Version 40 is different in that the prop must be stationary to set the timing. Thus a spinning P-mag will not allow its timing to be changed.
So to answer the question, this problem was solved in late 2014, so depending on the vintage of your P-mags, you want to get them in for the update.-------------------
Good explanation. Thanks. Good to know why instead of just do it. Larry
Old 11-25-2016, 04:35 PM
N941WR's Avatar
The next question is, "How do I know what version I have?"
The software fix came out in the fall of 2014. So, if you have had your P-mags back for a check up, they will have been upgraded to V40.
If you bought your P-mags prior to that and have not had them back since late 2014, you probably do not have V40.
1. There should be a sticker on the P-mags that list the version number, hopefully you can read it.
2. Put the P-mags in setup mode (powered AND grounded), move the prop to TDC and blow in the tube twice, observing the LED. If the P-mags let you set the timing you do NOT have Version 40. (Version 40 will not let you set the timing if the prop moves after being put in setup mode.)
3. If not, then you can connect to each P-mag with a PC via the P-mag's serial port (Pin's 2 & 3) and query them via the free EICAD program, available on the Emag website.
4. You can query them with an EICommander.
Those four options are listed in the order of expense.
Bill R.
SC86 - Easley, SC
Old 11-25-2016, 05:09 PM
N941WR's Avatar
Added #2, above.
Bill R.
SC86 - Easley, SC
Old 11-26-2016, 02:22 AM
rv8ch's Avatar
rv8ch rv8ch is online now
Default Code update required
Thanks for the heads up on this possible failure mode.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-26-2016, 09:15 AM
flightlogic's Avatar
Default one more observation
Just a quick observation. I would not be hesitant to shut down the offending ignition source in flight. Thinking that it might be worse... just continues the rough operation. Planes fly just fine on one. Check left and right when roughness occurs. Then shut off the bad one. Simple and safe. You did go richer, which was probably a good move. Switching tanks to rule out contamination might be prudent also. Glad this thread go started... and I think most of us are fine with the title.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 11-26-2016, 10:09 PM
gbusterguy gbusterguy is offline
We suspected an ignition problem and we were mostly concerned about turning off the good one and creating a strong backfire situation that could do more damage. Right or wrong that was the thinking. I do however understand the conventional thinking behind the mag check but it was running, not great but moving us along. We decided if it got worse we would do the mag the check. Since overheating was occurring fuel didn't seem to be the problem but I agree switch the tanks was in order. I will say that having another very experienced pilot in the cockpit to think through this compound emergency situation was extremely helpful. It's sobering to think about the flight just prior to this one, it was at night with my wife!
Loal Wood
RV 7, 2006, Superior XP IO360
Hartzel Blended Airfoil
[I]Owner of Wild Blue Innovations[/i]
Old 11-27-2016, 07:17 AM
6 Gun 6 Gun is offline
Thumbs down p mag
Sounds like the P mag company needs to pay to fix this guys engine if he was not notified of problem.
Bob
