Old 11-25-2016, 07:56 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Default Nose gear wheel pant question
On all of my nose gear Rv's I have had a tough time slipping the aft section of the wheel pant over the bracket. To date, I have split 2 wheel pants by trying to spread the bottom far enough to slip over the metal bracket. Any suggestions to ease over that aft part of the bracket? I know I'm not the first to have this issue. Thanks all and have a great holiday season.
Old 11-25-2016, 08:51 AM
Walt's Avatar
Walt Walt is offline
Assuming you have the new style brackets... they are meant to stay attached to the aft wheel pant and you slide the entire assembly aft to remove it, with the brackets attached.
I have seen some installed without the bracket slots cut per plans preventing it from sliding off as designed.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-26-2016, 07:15 AM
woodmanrog's Avatar
Thanks Walt,
I never thought of that. Taking off the two allen bolts would make things a lot easier. I'll check it out today.
Cheers
Old 11-26-2016, 07:39 AM
Rupester Rupester is offline
Putting the nose wheel pant on is the only aggravating task on the bottom side of my Nine-A .... For exactly the reason you articulate. Have scratched more skin and barked more knuckles doing that than any other maintenance chore. Other than band-Aides. , I haven't found a solution yet.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-26-2016, 09:41 AM
rvbuilder2002's Avatar
Walt explained it.
With the new style brackets (actually not new any more....they have been standard for a long time) you remove the two Allen cap screws and slide the wheel pant and brackets aft, off of the axle.
Scott McDaniels
Hubbard, Oregon
Old 11-26-2016, 03:51 PM
woodmanrog's Avatar
It works as described above. Too simple.
