Old 11-25-2016, 12:25 AM
Pheonix137's Avatar
Pheonix137 Pheonix137 is offline
Default Angle valve case, Parallel valve cylinders?
Can you fit parallel valve cylinders to an angle valve case? Obviously pushrod length changes, But I cannot see anything else that might be a problem - with the exception perhaps of the shroud tube angle?
RV7 #1: "Miss Daisy" IO360,Full MGL panel. SOLD
RV7 #2: "Sapphire Mistress" In progress. MGL panel,IO-360E1AD, Whirlwind GA200 prop. Light, Simple and FUN! SOLD
Lancair 235: Fun build. SOLD
Thorp T18C: Restoration underway...
Old 11-25-2016, 11:25 AM
jrs14855 jrs14855 is offline
Default Case
This used to be very common in the aerobatic community. Most popular was Piper Seneca One crankcases(angle valve engine) with front mounted governor to accommodate constant speed prop. Parallel valve cylinders. The previous iteration of Firewall Forward built some of these engines.
Old 11-25-2016, 11:28 AM
cajunwings cajunwings is offline
Default Cylinders
Shroud tubes look the same on all cylinders. The "angle" part happens right at the valve itself.
Don B
RV-9 Rebuild in Progress
Old 11-25-2016, 12:05 PM
g zero g zero is offline
Default Angle valve
Why ????? Seams like a waste of HP potential
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 11-25-2016, 12:21 PM
mahlon_r mahlon_r is offline
from a crankcase perspective the two styles of cylinder's are interchangeable. The cases are the same. So the cylinders will bolt up regardless of type they are to any 320,360 standard case. but the intakes, push tubes and rods rockers etc. are all different.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 11-25-2016, 03:31 PM
Default Why?
On the Pitts S1 this was done to keep the weight and balance under control. Allows the use of a lightweight constant speed without major issues with CG. Parallel valve engine can be hot rodded to 200 hp.
The Pitts flies much nicer if the CG is kept where it belongs along with keeping the total weight under control.
If you can live with a fixed pitch prop no need for the IO crankcase.
