Old 11-23-2016, 04:26 PM
unitink72 unitink72 is offline
Default Simple time logging script
Thought I would share this in case anyone else finds it useful.
I wrote a very simple time logging script in python. You run it, and it just sits there asking when you want to start the timer. After starting, you can either cancel or end. And if you end, you can put in a comment. It produces a csv file that you can read in excel:
Start Time, End Time, Elapsed Time, Comment
2016-11-16 20:27:01, 2016-11-16 22:33:47, 7605, inventory
2016-11-17 20:11:47, 2016-11-17 22:34:23, 8555, inventory done
2016-11-18 09:08:02, 2016-11-18 12:17:45, 11382, 6-2 VS spar
Here is the code. You may want to customize logFileName. I run this on linux, hence the unix-style path.
Code:
import datetime
import os.path
logFileName = '/home/tink/rv/rvWorkLog.txt'
userIn = ''
startTime = 0
endTime   = 0
if not os.path.isfile(logFileName):
     print('Log does not exist %s' % logFileName)
     userIn = input ('Create it? [Y/N]  ')
     if 'y' in userIn or 'Y' in userIn:
          logF = open(logFileName, 'w+')
          logF.write('Start Time, End Time, Elapsed Time, Comment\n')
          logF.close()
     else:
          exit ('Exiting')
while (1):
     while ('s' not in userIn):
          userIn = input ('[s]tart          ')
     startTime = datetime.datetime.now()
     while ('e' not in userIn and 'c' not in userIn):
          userIn = input ('[e]nd [c]ancel   ')
     if 'c' in userIn:
          continue
     endTime = datetime.datetime.now()
     userIn = input ('Comment          ')
     logF = open(logFileName, 'a')
     logF.write('%s, %s, %s, %s\n' % (startTime.strftime('%Y-%m-%d %H:%M:%S'), \
                                      endTime.strftime('%Y-%m-%d %H:%M:%S'),   \
                                      (endTime - startTime).seconds,           \
                                      userIn))
     userIn = ''
     logF.close()
#end while
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2019 Dues Paid
Old 11-24-2016, 06:51 AM
rdamazio's Avatar
rdamazio rdamazio is offline
Thought I'd share my time tracking solution - I already take timelapse videos of my build anyway. Each day after I'm done, I download the video, take the time in seconds and put it in a spreadsheet. Since it's recording at 2fps, I multiply by 15 to get the actual time (no, I don't account for drop-frame ).
Here's my time spreadsheet, done entirely that way:
https://docs.google.com/spreadsheets...l_WYyNEHU/edit
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
