11-22-2016, 08:43 AM
Pipe thread sealant Question
Is there any particular pipe thread sealant to use between the fuel filter and the fuel pump?
Loctite 567?
thanks
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
11-22-2016, 06:16 PM
I used Permatex #2 just like used for the fuel tank drain....
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
https://www.atkinsonurology.com
11-23-2016, 06:16 AM
Loctite 567 is a good product as long as you give it time to cure.
11-23-2016, 06:52 AM
#2 or my favorite (for 4 decades) , Aviation #3
Bill
RV-7
Lord Kelvin:
11-23-2016, 12:18 PM
Great stuff! It's an anaerobic cure, so the stuff that squishes out past the threads is always going to be a little gooey. I try to wipe off the excess as much as possible.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
11-23-2016, 07:49 PM
Leaks
I used Perm #2 at first. Then I disassembled, cleaned, and reassembled all fuel and brake lines with Locktite 567 to stop the leaks.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
11-23-2016, 10:49 PM
Just out of curiosity, what did you use or do to clean the threads when you changed the sealant?
11-23-2016, 11:53 PM
Pipe Thread Sealant
Napa India Head Gasket Shellac. Works like a charm - after 1.5 years of fighting Brake line "weeps" and a couple of fuel line leaks. Just don't get the shellac on the mating surfaces of the fittings or inside the pipe end.
Let the fittings set for 24 hours before introducing brake fluid or fuel (as appropriate) to the line.
11-24-2016, 04:53 AM
Pneumatic and Hydraulic Sealant
I use Pneumatic and Hydraulic Sealant everywhere except fuel lines. I don't know if it's compatible with fuel, but it works great on brake and hydraulic lines. It's like Loctite and is what heavy equipment manufacturers use on their bulldozers and track hoes.
(2020 dues paid)
11-24-2016, 07:37 AM
Permatex #2 and #3 are removable with alcohol. Isopropyl or denatured ethanol. Nothing petroleum will touch it.
Bill
RV-7
Lord Kelvin:
