Old 11-18-2016, 05:02 PM
omrsramsay's Avatar
omrsramsay omrsramsay is offline
Default Wing Jacks
I should have asked here first. I couldn't find a suitable jack, so I made my own. What are RV owners using for jacks?
http://tinyurl.com/RV3-Jack
John Kimmel
http://www.youtube.com/watch?v=ZOa7Xsc2P_M
Old 11-18-2016, 05:53 PM
rolivi's Avatar
rolivi rolivi is offline
dead link.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 11-18-2016, 06:39 PM
I haven't addressed this yet, but I was thinking about getting one of these, then bolting up a wooden box to bridge the gap between the top of the jack and bottom of the wing. I'd put a chunk of 2x6 on top of the box, and drill a hole in it to index a bolt fitted to the wing tie-down socket. The 2x6 would be under the spar, of course, to distribute the load.
What do you think? And what's the typical dimension from the ground to the underside of a -9A wing?
http://www.harborfreight.com/1500-lb...ift-60536.html
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 11-18-2016, 08:00 PM
jpowell13 jpowell13 is offline
Default Old dog
I built a couple of milk stools and bought some of those jack points from Anti-splat. Not very original but it's cheap and works. Just want to make sure the wheels on the ground are chocked. John
Old 11-18-2016, 09:20 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Default Search?
Dont recreate the wheel. Do a search for wing jacks on this forum. Many good examples from the brain trust.
Keith
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 11-20-2016, 01:03 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Whole plane
I use one of these to lift the whole plane from under the main spar pass-through. A box roughly 1' by 1' fits over the rails and has a 2' by 3' plywood top covered by 2" pink foam. Antenna placement during construction was made with this procedure in mind. This only works for maintenance outside the plane. You don't want to be jumping on the step while the plane is balanced in the air.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
